Code 132 - Graylog 3.2 on RedHat 7
I am trying to run the latest docker image for graylog 3.x and I can’t make it work, I’m receiving Exit Code 132.
Red Hat Enterprise Linux 7.8
Some spec about the server:
For a workaround I’m using the Graylog 2.x
please share your docker run command or docker compose.
in addition what exact image did you use?
Hi Jan
$ docker run --name graylog --link mongo --link elasticsearch
-p 9000:9000 -p 12201:12201 -p 1514:1514
-e GRAYLOG_HTTP_EXTERNAL_URI=“http://127.0.0.1:9000/
-d graylog/graylog:3.2
Image: graylog/graylog:3.2
Tried also others 3.x and same issue
he @thiagoloureiro
I have copied and pasted the quick start from https://docs.graylog.org/en/3.2/pages/installation/docker.html#quick-start
 ~ docker ps
CONTAINER ID        IMAGE                                                     COMMAND                  CREATED             STATUS                   PORTS        NAMES
f0668be66e37        graylog/graylog:3.2                                       "tini -- /docker-ent…"   2 minutes ago       Up 2 minutes (healthy)   0.0.0.0:1514->1514/tcp, 0.0.0.0:9000->9000/tcp, 0.0.0.0:12201->12201/tcp   graylog
776306bd5ca5        docker.elastic.co/elasticsearch/elasticsearch-oss:6.8.5   "/usr/local/bin/dock…"   3 minutes ago       Up 3 minutes             9200/tcp, 9300/tcp                                                         elasticsearch
5ef7d9aadea3        mongo:3                                                   "docker-entrypoint.s…"   4 minutes ago       Up 4 minutes             27017/tcp        mongo
I pulled all images as clean images right for that start. In the past we had a broken health script and that might be the reason.
Did you checked CPU and RAM on your system? is that all available and configured proper to work? Does the CPU allow virtualisation at all?
