Changing Default Passwords
Hi, New to Graylog and I’m trying to change the default web and OS passwords. For the web password I tried to run “sudo graylog-ctl set-admin-password mynewpassword” . After this command and a “sudo graylog-ctl reconfigure” I could not login to the web interface as admin mynewpassword or admin admin. I then found a document after some searching to do the following:
  1. Generate a Secret Key.
    pwgen -N 1 -s 96
  2. Put it under “password_secret =” in /opt/graylog/conf/server.conf
  3. Generate a Hash password
    echo -n yourpassword | shasum -a 256
  4. Put it Under “root_password_sha2 =” in /opt/graylog/conf/server.conf
  5. I ran “sudo graylog-ctl reconfigure”
I still haven’t been able to login. I’ve been checking and rechecking for hours. Any help would be greatly appreciated.
Thanks,
Paul
Hej @rollin
from what you had written I think you are using some kind of OVA/Image installation. All changes to that kind of installation need to made via the graylog-ctl command.
Using sudo graylog-ctl set-admin-password mynewpassword followed by sudo graylog-ctl reconfigure should have done the trick. Did you push a sudo graylog-ctl restart after the reconfigure - just to be sure that Graylog is taking the new configuration.
If not what can be found in the Graylog Server Logfile? The location can be checked here:
http://docs.graylog.org/en/2.3/pages/configuration/file_location.html#omnibus-package
Thanks for the reply. I had used graylog-ctl with a complex password and maybe I miss typed something. I followed your instructions with a simple password and it worked. Thank You.
The installation is an OVA image that I converted to Hyper-V.
Thanks again
how about for not ova?
i installed it in manual from scratch, however after all the install had done and graylog pag were now accessible but cannot login using user:admin and password: admin
Can you help about it>
Thanks!
Please refer to http://docs.graylog.org/en/2.3/pages/installation/manual_setup.html#configuration for information about the manual installation of Graylog.
