I can’t login Graylog web interface by default user admin , password admin.
after fill admin both user/password , Graylog show invalid credentials
Can you please answers me correct both username/password for login Graylog web interface.
Are you using default VM downloaded from graylog? If so try using graylog-ctl or if you have built by yourself then change the password and edit in graylog.conf
Hi blason,
Yes, I using default VM from graylog version graylog-3.1.0-6.
Do you have screenshot how to change password or not ?
Thnak you in advance.
you might want to read the documentation where the password would have been shown to you:
http://docs.graylog.org/en/3.1/pages/installation/virtual_machine_appliances.html
plus you might want to search this community how to reset that.
Hi Jan,
I already reset password graylog web interface.
Thanks.
