Cannot get web admin to work
Trying graylog enterprise using the docker images but the web interface wont work. I can nc or curl to the correct IP but I can see it is trying the docker bind address.
192.168.210.6 is the IP address of the Centos 7 machine I am starting docker on.
#docker-comose.yml
    version: '2'
    services:
      mongo:
        image: mongo:3
        volumes:
          - mongo_data:/data/db
      # Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/5.5/docker.html
      elasticsearch:
        image: docker.elastic.co/elasticsearch/elasticsearch:5.6.12
        volumes:
        environment:
          - http.host=0.0.0.0
          - transport.host=localhost
          - network.host=0.0.0.0
          # Disable X-Pack security: https://www.elastic.co/guide/en/elasticsearch/reference/5.5/security-settings.html#general-security-settings
          - xpack.security.enabled=false
          - xpack.watcher.enabled=false
          - xpack.monitoring.enabled=false
          - xpack.security.audit.enabled=false
          - xpack.ml.enabled=false
          - xpack.graph.enabled=false
        ulimits:
          memlock:
            soft: -1
            hard: -1
        mem_limit: 1g
      graylog:
        image: graylog/graylog:3.0
        #network_mode: bridge
        volumes:
          - /opt/docker/graylog/graylog/data/journal:/usr/share/graylog/data/journal
          #- /opt/docker/graylog/graylog/config:/usr/share/graylog/data/config
        environment:
          - GRAYLOG_WEB_ENDPOINT_URI=http://192.168.210.6:9000/api/
          - GRAYLOG_REST_TRANSPORT_URI=http://192.168.210.6:9000
        links:
          - mongo
          - elasticsearch
        ports:
          - 9000:9000
          # Syslog TCP
          - 514:514
          # Syslog UDP
          - 514:514/udp
          # GELF TCP
          - 12201:12201
          # GELF UDP
          - 12201:12201/udp
    # Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
    volumes:
      mongo_data:
        driver: local
      es_data:
        driver: local
      graylog_journal:
        driver: local
curl -l http://192.168.210.6:9000
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <meta name="robots" content="noindex, nofollow">
    <meta charset="UTF-8">
    <title>Graylog Web Interface</title>
    <link rel="shortcut icon" href="http://172.19.0.4:9000/assets/favicon.png">
  </head>
  <body>
    <script src="http://172.19.0.4:9000/config.js"></script>
    <script src="http://172.19.0.4:9000/assets/vendor.3a39c01292ce2ef4ffed.js"></script>
    <script src="http://172.19.0.4:9000/assets/polyfill.911fcb4337d67c175fec.js"></script>
    <script src="http://172.19.0.4:9000/assets/builtins.911fcb4337d67c175fec.js"></script>
    <script src="http://172.19.0.4:9000/assets/plugin/org.graylog.plugins.threatintel.ThreatIntelPlugin/plugin.org.graylog.plugins.threatintel.ThreatIntelPlugin.8b790b2249be29b14101.js"></script>
    <script src="http://172.19.0.4:9000/assets/plugin/org.graylog.plugins.collector.CollectorPlugin/plugin.org.graylog.plugins.collector.CollectorPlugin.fe849445e7e2ab2d2bbe.js"></script>
    <script src="http://172.19.0.4:9000/assets/plugin/org.graylog.aws.AWSPlugin/plugin.org.graylog.aws.AWSPlugin.5a135f262866542ed363.js"></script>
    <script src="http://172.19.0.4:9000/assets/app.911fcb4337d67c175fec.js"></script>
  </body>
</html>
two issues I can spot instand:
  1. you use the Image: graylog/graylog:3.0 what is not present ( https://hub.docker.com/r/graylog/graylog/tags/ )
    1.1 only 3.0.0-alpha.4-1 is given
  2. Graylog 3.0 is alpha AND has changed configuration options compared to 2.x
    2.1 See 3.0 Documentation on that: http://docs.graylog.org/en/3.0/pages/configuration/server.conf.html?#web-rest-api
In addition I would no use the 3.0 alpha build for production - only for testing. 2.4.6 is the current stable release at the time of writing this and you can use the tag 2.4 on from docker hub.
ah ok will start again thanks.
