Can I get charts similar to Kibana on graylog?
Hi Team
I have worked in Kibana and was able to create charts. Support was provided by Kibana to have charts with name of the metric on x-axis and count/min-time/max-time on y-axis. Can I configure similar charts on GrayLog. Please help.
If not, is there any way to integrate Kibana with Graylog?
Here in this integrated Graylog Kibana application, can I still utilize all the other options like user and role-based access provided by Graylog?
Srumith.
No, but you can use Kibana with the indices created by Graylog.
No.
Thanks a lot for responding !!
Hi Jochen,
As user and role-based access are not available when using Kibana plugged on the indices created by Graylog, what would you advice as the best move forward to give our users access to a reporting GUI as fancy as Kibana or Splunk but with limited access rights and decent pricing ?
Rgds
BH
