I installed graylog, and upgraded it on debian 10. I then installed the package for the enterprise version, rebooted. Subscribed to try out the small business license. I then go into enterprise/licenses, licenses, and add the license I got by email. It is a PGP file. Once I try to do that I get this error message:
### Invalid license
**Reason** : Unable to parse license. Check if required fields are missing: JWT strings must contain exactly 2 period characters. Found: 0
If I randomly add two periods to the license I get this message:
Unable to parse license. Check if required fields are missing: JWT string '..-
Both of them followed by the license key.
OS Information:
Debian GNU/Linux 10 -
Package Version:
Graylog 4.2.4+b643d2b -
None, since it seems to be a bug.
Help understand why this error might be coming up, and see if there is any additional configuration that can or should be done in order to correct it.
