Installation of graylog small business license with docker
I am using graylog-entreprise 4.3.2 but i want to use a small business license.
The cluster id and the node id are not the same. I tried to apply the license but the license is not apply with this message :
Violations detected
This cluster is not covered by the license.
How can I resolve this ?
  • OS Information: docker
  • Package Version: graylog 4.3.2
I tried to generate a licence with cluster id but without success.
Hello && welcome @drobert31
This is correct.
When sign up for a license there should have been a email sent with the license txt file attached.
You have a couple choices. Either ask for a new license and remove the old one through Web UI or get the Email that was sent and copy & paste it here.
If your having further troubles perhaps @dscryber could direct you.
Thanks for your answer.
I asked for a new license for the cluster id. But when I enter the licence, I have got message :
Violations detected
Remote checks have failed too many times.
Any Ideas ?
Thanks,
Dominique
I haven’t had that happen yet.
Is your issue/s something like this?
No, I am not in that case, about 800MB / day.
Perhaps, some persistent data in the database ?
Dominique
