“AWS S3 Input” is not available in Graylog 6.2
1. incident:
I’m currently migrating from an older version of Graylog and need the AWS S3 input. However, it doesn’t appear in the list of available inputs in my instance. According to the official documentation, this feature was introduced in Graylog 6.2, but I’m still unable to find it.
Is there anything additional I need to enable or install to access the AWS S3 input?
  • OS Information: Ubuntu 24.04.2 LTS (AWS EC2)
  • Deployment method: Docker
  • Graylog version: graylog/graylog:6.2 (specifically version 6.2.2+13ba949 )
  • Java version: Eclipse Adoptium 17.0.15
  • Kernel: Linux 6.8.0-1029-aws
  • Verified the documentation that AWS S3 input should exist in Graylog 6.2+
  • Checked all available input types in the Graylog UI
  • Restarted the container to see if the input appears
  • Verified that the image tag 6.2.2 is being used
  • Used old plugin here - input start but not working.
  • Confirm whether the AWS S3 input is included by default in the official Docker image
  • Advise if a plugin or additional configuration is needed
  • Share troubleshooting steps or experience enabling this input in a similar environment
