Can't start inputs
Running graylog in docker. Followed docker installation process here: Docker - Installing Graylog. No inputs start. “Request to start input failed, Check your graylog logs for more information”
  • OS Information:
    Docker running on Ubuntu 21.10
  • Package Version:
    Graylog 4.2.5+59802bf
    GRAYLOG_PASSWORD_SECRET
    GRAYLOG_ROOT_PASSWORD_SHA2
    GRAYLOG_HTTP_PUBLISH_URI
    GRAYLOG_HTTP_EXTERNAL_URI
verified correct environment variables. In error message it indicates to look for logs, but I cannot find them within the docker container.
Being able to find the Graylog logs in the docker container indicated in the error message would be good start. Without that I do not have much information as to whats actually wrong.
Hello && Welcome @icsj2007
Ill be honest, I’m not good with Docker but I maybe able to help troubleshoot this issue with you.
This would help, what i found about GL Docker was from here
And this…
And I ran into this forum for Docker.
I believe if you can find your log4j2.xml ( Should be in your Graylog Directory) this should point where your log files are.
As for your Elasticsearch logs with Docker, I have found this. It may help later on.
Normally your Graylog log files would be located in /var/log/graylog-server
