I am in web interface my system inputs collection of logs are running but there is no message so I did not understand why
My incident are only in web interface my all service are running
  • OS Information:
  • Package Version:7
All running
I read all the community
By answer the question
Have you tried manually sending a message using curl or netcat?
No I will not try that but this is in web interface I find that I it is not connected to that computer from where I collect log so if you will guide me about that
Is this even possible for port 9000 being the entry port to the web-interface of graylog?
@Osman Could I ask if this is a new installation and if so what guide did you follow?
It appears to be port 9000 UDP so it should still work, you can test with the below command from shell altering the IP address to that of your Graylog instance.
echo '<14>syslog-test-source testing testing 123' | nc -v -u -w 0 192.168.69.3 9000
Any progress on that?
I created the docker-compose like in documentation, start up and configure a input GELF UDP and didn’t work… nwither with curl command
my setup:
graylog:
hostname: “server”
image: “graylog/graylog:6.0.5”
# To install Graylog Open: “graylog/graylog:6.0”
depends_on:
mongodb:
condition: “service_started”
opensearch:
networks:
- graylog
entrypoint: “/usr/bin/tini – wait-for-it opensearch:9200 – /docker-entrypoint.sh”
environment:
# - GRAYLOG_NODE_ID_FILE=“/usr/share/graylog/data/config/node-id”
- GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0 #0.0.0.0:9000
- GRAYLOG_ELASTICSEARCH_HOSTS=http://opensearch:9200
- GRAYLOG_MONGODB_URI=mongodb://mongodb:27017/graylog
# To make reporting (headless_shell) work inside a Docker container
- GRAYLOG_REPORT_DISABLE_SANDBOX=true
- GRAYLOG_PASSWORD_SECRET=somepasswordpepper
# Password: “admin” → u: admin p: admin → 8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
- GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
- GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
ports:
GELF TCP
  - "12201:12201/tcp"
  # GELF UDP
  - "12201:12201/udp"
  - "9000:9000/tcp"
Thanks for reply I am doing my internship so I did not understand why my logs are not seeing and I have to submit my project in 5 days and now my internship is finish and I have submitted my project in time so I concluded this
