An input has failed to start...but all my inputs are already running
I’m running Graylog 3.2 on Docker (Ubuntu host). Everything else is working 100%, this is my only issue.
I’m receiving the message below every time I restart the Graylog docker container. I’ve tried to clear this notification, but it comes back every time I restart Graylog.
Input 5eacbada64904500124b51bb has failed to start on node 1df75265-96a0-49a4-b387-6303a72b0549 for this reason: »null«.
However, I only have 2 inputs, and they’re both started and working. Where is input 5eacbada64904500124b51bb? Is there a field in the database that I can remove?
Below is my logfile where you can see the input try to start, then fail.
2020-05-02 00:44:57,617 INFO : org.graylog2.inputs.InputStateListener - Input [Syslog UDP/5eacbada64904500124b51bb] is now STARTING
2020-05-02 00:44:57,621 INFO : org.graylog2.inputs.InputStateListener - Input [Syslog UDP/5eacbada64904500124b51bf] is now STARTING
2020-05-02 00:44:57,623 INFO : org.graylog2.inputs.InputStateListener - Input [Syslog UDP/5eacbada64904500124b51bf] is now STOPPING
2020-05-02 00:44:57,626 INFO : org.graylog2.inputs.InputStateListener - Input [Syslog UDP/5eacbada64904500124b51bf] is now TERMINATED
2020-05-02 00:44:57,629 INFO : org.graylog2.inputs.InputStateListener - Input [Syslog UDP/5eacbada64904500124b51bb] is now STOPPING
2020-05-02 00:44:57,631 INFO : org.graylog2.inputs.InputStateListener - Input [Syslog UDP/5eacbada64904500124b51bb] is now STOPPED
2020-05-02 00:44:57,634 INFO : org.graylog2.inputs.InputStateListener - Input [Syslog UDP/5eacbada64904500124b51bb] is now TERMINATED
2020-05-02 00:44:57,637 INFO : org.graylog2.inputs.InputStateListener - Input [Syslog UDP/5eacbada64904500124b51bf] is now STOPPED
2020-05-02 00:44:57,716 ERROR: org.graylog2.shared.inputs.InputLauncher - The [org.graylog2.inputs.syslog.udp.SyslogUDPInput] input with ID <5eacbada64904500124b51bb> misfired. Reason: null
org.graylog2.plugin.inputs.MisfireException: org.graylog2.plugin.inputs.MisfireException: java.lang.NullPointerException
	at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:158) ~[graylog.jar:?]
	at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:84) [graylog.jar:?]
	at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_242]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_242]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_242]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_242]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_242]
Caused by: org.graylog2.plugin.inputs.MisfireException: java.lang.NullPointerException
	at org.graylog2.inputs.transports.UdpTransport.launch(UdpTransport.java:135) ~[graylog.jar:?]
	at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
	... 7 more
Caused by: java.lang.NullPointerException
	at org.graylog2.inputs.transports.UdpTransport.launch(UdpTransport.java:130) ~[graylog.jar:?]
	... 7 more
2020-05-02 00:44:57,718 ERROR: org.graylog2.shared.inputs.InputLauncher - The [org.graylog2.inputs.syslog.udp.SyslogUDPInput] input with ID <5eacbada64904500124b51bf> misfired. Reason: null
	... 7 more
	... 7 more
2020-05-02 00:44:57,727 INFO : org.graylog2.inputs.InputStateListener - Input [Syslog UDP/5eacbada64904500124b51bb] is now FAILED
2020-05-02 00:44:57,731 INFO : org.graylog2.inputs.InputStateListener - Input [Syslog UDP/5eacbada64904500124b51bf] is now FAILED
