burd
August 15, 2018, 3:49pm
1
Input shows running in logs but GUI shows “Request to start input failed” and it is not working.
Input[Syslog UDP…] is now RUNNING
Input[Syslog UDP…] is now STARTING
log]# netstat -uldn | grep 1514
udp 0 0 0.0.0.0:1514 0.0.0.0:*
jan
(Jan Doberstein)
August 16, 2018, 8:13am
2
how is your input configured? Did you have other inputs? How are they configured?
What process is listening on the Port?
burd
August 16, 2018, 1:14pm
3
Hi Jan,
I am trying to set up a simple syslog input. This is our only input. We are not using the OVA. Initially, we received the permissions error for th elow port number. I then followed your docs and changed the iptables routing so outside its 514 and inside its 1514. lsof -i :1514 shows nothing.
Thanks!
-bash-4.2$ lsof -i :1514
allow_override_date:
true
bind_address:
0.0.0.0
expand_structured_data:
false
force_rdns:
false
override_source:
<empty>
port:
1514
recv_buffer_size:
262144
store_full_message:
false
burd
August 16, 2018, 2:10pm
5
Via RPM onto OEL 7. This is from graylog.log. It doesn’t look like it pertains. Should I be looking somewhere else?
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_171]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_171]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_171]
TheUI shows Input could not be started. Request to start input failed.
jan
(Jan Doberstein)
August 16, 2018, 2:57pm
6
those lines you paste are parts of a multiline stack trace. The beginning is a date and if the next date appears the one message ends.
With the given Information I’m not able to help
burd
August 16, 2018, 3:28pm
7
I agree, however this is what it was showing during the time start input was clicked on.
2018-08-15 10:42:57,428 INFO : org.graylog2.bootstrap.ServerBootstrap - Services started, startup times in ms: {InputSetupService [RUNNING]=15, JournalReader [RUNNING]=21, OutputSetupService [RUNNING]=79, BufferSynchronizerService [RUNNING]=94, ConfigurationEtagService [RUNNING]=109, StreamCacheService [RUNNING]=197, KafkaJournal [RUNNING]=217, PeriodicalsService [RUNNING]=623, LookupTableService [RUNNING]=688, JerseyService [RUNNING]=24718}
2018-08-15 10:42:57,448 INFO : org.graylog2.bootstrap.ServerBootstrap - Graylog server up and running.
2018-08-15 10:42:57,458 INFO : org.graylog2.shared.initializers.InputSetupService - Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2018-08-15 10:44:32,340 INFO : org.graylog2.inputs.InputStateListener - Input [Syslog UDP/5b743c4f7317ec62f90ae40d] is now RUNNING
burd
August 16, 2018, 3:29pm
8
Let me know if there is something specific you want me to look for.
jan
(Jan Doberstein)
August 17, 2018, 7:42am
9
after this line their will be something giving you the idea why it is failing:
As you did not provide the complete log you need to look at yourself.
burd
August 17, 2018, 12:00pm
10
A colleague discovered the issue. Thanks for your replies.
jan
(Jan Doberstein)
August 17, 2018, 12:27pm
11
sharing is caring - so other member of the community can learn …
