No input available
I installed a graylog server on CentOS7 (fresh installation). I tried to add inputs using the option ‘System/Inputs > Inputs > Select Inputs’, but it says ‘No inputs available’.
Please help!
Hej @rahul
you need to create an Input System > Inputs then select in the drop-down the type after that hit launch new input.
If you have any more question you should give some more details what you have done and what is not working.
I did that in the same way, but dropdown is empty with the message No inputs available. It’s fresh installation.
you should check your graylog server.log for any errors or missing plugins.
I have restarted graylog-server service and obtained following logs while starting on /var/log/graylog-server/server.log.
2017-06-06T14:45:33.487+04:00 INFO [CmdLineTool] Loaded plugin: Elastic Beats Input 2.2.3 [org.graylog.plugins.beats.BeatsInputPlugin]
2017-06-06T14:45:33.494+04:00 INFO [CmdLineTool] Loaded plugin: Collector 2.2.3 [org.graylog.plugins.collector.CollectorPlugin]
2017-06-06T14:45:33.496+04:00 INFO [CmdLineTool] Loaded plugin: Enterprise Integration Plugin 2.2.3 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2017-06-06T14:45:33.498+04:00 INFO [CmdLineTool] Loaded plugin: MapWidgetPlugin 2.2.3 [org.graylog.plugins.map.MapWidgetPlugin]
2017-06-06T14:45:33.510+04:00 INFO [CmdLineTool] Loaded plugin: Pipeline Processor Plugin 2.2.3 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2017-06-06T14:45:33.511+04:00 INFO [CmdLineTool] Loaded plugin: Anonymous Usage Statistics 2.2.3 [org.graylog.plugins.usagestatistics.UsageStatsPlugin]
2017-06-06T14:45:33.894+04:00 INFO [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=rpm
2017-06-06T14:45:34.341+04:00 INFO [Version] HV000001: Hibernate Validator null
2017-06-06T14:45:37.790+04:00 INFO [InputBufferImpl] Message journal is enabled.
2017-06-06T14:45:37.839+04:00 INFO [NodeId] Node ID: 4771c246-c1f9-4100-bf45-71923c5375cb
2017-06-06T14:45:38.178+04:00 INFO [LogManager] Loading logs.
2017-06-06T14:45:38.271+04:00 INFO [LogManager] Logs loading complete.
2017-06-06T14:45:38.272+04:00 INFO [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2017-06-06T14:45:38.289+04:00 INFO [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy , running 2 parallel message handlers.
2017-06-06T14:45:38.324+04:00 INFO [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout=‘30000 ms’, maxWaitQueueSize=5000}
2017-06-06T14:45:38.392+04:00 INFO [cluster] No server chosen by ReadPreferenceServerSelector{readPreference=primary} from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=localhost:27017, type=UNKNOWN, state=CONNECTING}]}. Waiting for 30000 ms before timing out
2017-06-06T14:45:38.451+04:00 INFO [connection] Opened connection [connectionId{localValue:1, serverValue:8}] to localhost:27017
2017-06-06T14:45:38.458+04:00 INFO [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[3, 2, 13]}, minWireVersion=0, maxWireVersion=4, maxDocumentSize=16777216, roundTripTimeNanos=792084}
2017-06-06T14:45:38.472+04:00 INFO [connection] Opened connection [connectionId{localValue:2, serverValue:9}] to localhost:27017
2017-06-06T14:45:38.916+04:00 INFO [node] [graylog-4771c246-c1f9-4100-bf45-71923c5375cb] version[2.4.4], pid[4195], build[fcbb46d/2017-01-03T11:33:16Z]
2017-06-06T14:45:38.917+04:00 INFO [node] [graylog-4771c246-c1f9-4100-bf45-71923c5375cb] initializing …
2017-06-06T14:45:38.925+04:00 INFO [plugins] [graylog-4771c246-c1f9-4100-bf45-71923c5375cb] modules , plugins [graylog-monitor], sites
2017-06-06T14:45:41.458+04:00 INFO [node] [graylog-4771c246-c1f9-4100-bf45-71923c5375cb] initialized
2017-06-06T14:45:41.569+04:00 INFO [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy .
2017-06-06T14:45:43.583+04:00 INFO [RulesEngineProvider] No static rules file loaded.
2017-06-06T14:45:44.092+04:00 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-06T14:45:44.104+04:00 INFO [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy .
2017-06-06T14:45:44.200+04:00 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-06T14:45:44.317+04:00 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-06T14:45:44.398+04:00 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-06T14:45:44.486+04:00 WARN [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2017-06-06T14:45:45.693+04:00 INFO [ServerBootstrap] Graylog server 2.2.3+7adc951 starting up
2017-06-06T14:45:45.694+04:00 INFO [ServerBootstrap] JRE: Oracle Corporation 1.8.0_131 on Linux 3.10.0-514.21.1.el7.x86_64
2017-06-06T14:45:45.694+04:00 INFO [ServerBootstrap] Deployment: rpm
2017-06-06T14:45:45.694+04:00 INFO [ServerBootstrap] OS: CentOS Linux 7 (Core) (centos)
2017-06-06T14:45:45.694+04:00 INFO [ServerBootstrap] Arch: amd64
2017-06-06T14:45:45.701+04:00 WARN [DeadEventLoggingListener] Received unhandled event of type <org.graylog2.plugin.lifecycles.Lifecycle> from event bus <AsyncEventBus{graylog-eventbus}>
2017-06-06T14:45:45.998+04:00 INFO [node] [graylog-4771c246-c1f9-4100-bf45-71923c5375cb] starting …
2017-06-06T14:45:45.996+04:00 INFO [PeriodicalsService] Starting 26 periodicals …
2017-06-06T14:45:46.016+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2017-06-06T14:45:46.021+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.AlertScannerThread] periodical in [10s], polling every [60s].
2017-06-06T14:45:46.023+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2017-06-06T14:45:46.025+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2017-06-06T14:45:46.027+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical, running forever.
2017-06-06T14:45:46.036+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2017-06-06T14:45:46.039+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2017-06-06T14:45:46.040+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2017-06-06T14:45:46.041+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2017-06-06T14:45:46.044+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2017-06-06T14:45:46.045+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2017-06-06T14:45:46.046+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2017-06-06T14:45:46.047+04:00 INFO [IndexRetentionThread] Elasticsearch cluster not available, skipping index retention checks.
2017-06-06T14:45:46.055+04:00 INFO [connection] Opened connection [connectionId{localValue:5, serverValue:12}] to localhost:27017
2017-06-06T14:45:46.055+04:00 INFO [connection] Opened connection [connectionId{localValue:3, serverValue:10}] to localhost:27017
2017-06-06T14:45:46.059+04:00 INFO [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2017-06-06T14:45:46.060+04:00 INFO [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2017-06-06T14:45:46.068+04:00 INFO [connection] Opened connection [connectionId{localValue:4, serverValue:11}] to localhost:27017
2017-06-06T14:45:46.073+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2017-06-06T14:45:46.076+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2017-06-06T14:45:46.082+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2017-06-06T14:45:46.098+04:00 INFO [connection] Opened connection [connectionId{localValue:7, serverValue:14}] to localhost:27017
2017-06-06T14:45:46.101+04:00 INFO [connection] Opened connection [connectionId{localValue:6, serverValue:13}] to localhost:27017
2017-06-06T14:45:46.130+04:00 INFO [connection] Opened connection [connectionId{localValue:9, serverValue:16}] to localhost:27017
2017-06-06T14:45:46.129+04:00 INFO [connection] Opened connection [connectionId{localValue:8, serverValue:15}] to localhost:27017
2017-06-06T14:45:46.189+04:00 INFO [IndexerClusterCheckerThread] Indexer not fully initialized yet. Skipping periodic cluster check.
2017-06-06T14:45:46.210+04:00 INFO [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2017-06-06T14:45:46.211+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.AlarmCallbacksMigrationPeriodical] periodical, running forever.
2017-06-06T14:45:46.224+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2017-06-06T14:45:46.240+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical, running forever.
2017-06-06T14:45:46.243+04:00 INFO [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2017-06-06T14:45:46.276+04:00 INFO [Periodicals] Starting [org.graylog.plugins.usagestatistics.UsageStatsNodePeriodical] periodical in [300s], polling every [21600s].
2017-06-06T14:45:46.280+04:00 INFO [Periodicals] Starting [org.graylog.plugins.usagestatistics.UsageStatsClusterPeriodical] periodical in [300s], polling every [21600s].
2017-06-06T14:45:46.290+04:00 INFO [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2017-06-06T14:45:46.291+04:00 INFO [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2017-06-06T14:45:46.302+04:00 INFO [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2017-06-06T14:45:46.602+04:00 INFO [transport] [graylog-4771c246-c1f9-4100-bf45-71923c5375cb] publish_address {127.0.0.1:9350}, bound_addresses {[::1]:9350}, {127.0.0.1:9350}
2017-06-06T14:45:46.620+04:00 INFO [discovery] [graylog-4771c246-c1f9-4100-bf45-71923c5375cb] graylog/ubt_KjwWTpSYwVY2W0r4WQ
2017-06-06T14:45:46.646+04:00 INFO [V20161130141500_DefaultStreamRecalcIndexRanges] Cluster not connected yet, delaying migration until it is reachable.
2017-06-06T14:45:47.192+04:00 INFO [JerseyService] Enabling CORS for HTTP endpoint
2017-06-06T14:45:49.663+04:00 WARN [discovery] [graylog-4771c246-c1f9-4100-bf45-71923c5375cb] waited for 3s and no initial state was set by the discovery
2017-06-06T14:45:49.664+04:00 INFO [node] [graylog-4771c246-c1f9-4100-bf45-71923c5375cb] started
2017-06-06T14:45:50.190+04:00 INFO [service] [graylog-4771c246-c1f9-4100-bf45-71923c5375cb] detected_master {Force}{gjQMBObBT16PzKwGE2wItg}{127.0.0.1}{127.0.0.1:9300}, added {{Force}{gjQMBObBT16PzKwGE2wItg}{127.0.0.1}{127.0.0.1:9300},}, reason: zen-disco-receive(from master [{Force}{gjQMBObBT16PzKwGE2wItg}{127.0.0.1}{127.0.0.1:9300}])
2017-06-06T14:46:05.054+04:00 INFO [NetworkListener] Started listener bound to [192.168.11.53:9000]
2017-06-06T14:46:05.056+04:00 INFO [HttpServer] [HttpServer] Started.
2017-06-06T14:46:05.056+04:00 INFO [JerseyService] Started REST API at http://192.168.11.53:9000/api/
2017-06-06T14:46:05.057+04:00 INFO [JerseyService] Started Web Interface at http://192.168.11.53:9000/
2017-06-06T14:46:05.058+04:00 INFO [ServiceManagerListener] Services are healthy
2017-06-06T14:46:05.060+04:00 INFO [ServerBootstrap] Services started, startup times in ms: {KafkaJournal [RUNNING]=35, OutputSetupService [RUNNING]=53, BufferSynchronizerService [RUNNING]=54, InputSetupService [RUNNING]=135, JournalReader [RUNNING]=198, ConfigurationEtagService [RUNNING]=207, StreamCacheService [RUNNING]=207, PeriodicalsService [RUNNING]=305, IndexerSetupService [RUNNING]=4257, JerseyService [RUNNING]=19065}
2017-06-06T14:46:05.060+04:00 INFO [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2017-06-06T14:46:05.069+04:00 INFO [ServerBootstrap] Graylog server up and running.
Please advise if you can see anything wrong.
you should check if any adblocker / JSBlocker is running in your browser.
Hi
I don’t have any adblocker / JSBlocker in my browser, I tried on diff browsers as well.
I found one thing. Graylog server is on a NATed environment. I was accessing interface using public IP after doing port forwarding. When I accessed interface with local IP, it worked within network. I have added inputs and started to getting logs also. But when I checked using public IP, I’m not able to see inputs or logs. Did I miss any settings in graylog for NAT? I did port forwarding in below manner. Any more port forwarding required other than this?
PublicIP:9000 => LocaIP:9000
your browser need to be able to communicate with the Graylog REST-API.
look at the documentation about that setup.
