404 Error at /system/sessions. Can't login
I’ve just reinstalled Graylog on new server. Had 2.1 working perfectly before but I can’t manage to make the new version work.
There’s an NGING acting as a reverse proxy. The conf is as follows:
rest_listen_uri = is configured to port 12900 (can’t have 3 links in a post as a new user :confused:)
rest_transport_uri = https://api.xxx.com/
web_endpoint_uri = https://xxx.com/
What issues do you have exactly?
Also make sure to read http://docs.graylog.org/en/2.2/pages/configuration/web_interface.html
Putting the text in a pre-formatted block should help:
Text
Thank you for your prompt answer. I had already read the page you linked.
I can’t connect to Graylog because /system/sessions returns & 404 error (GET or POST).
I’m willing to have a setup with rest_listen_uri to a different port than web_endpoint_uri, as it was in the older versions.
I’ve set up two domain names:
  • api.graylog.xxx.com
  • graylog.xxx.com
My configuration is as follows:
rest_listen_uri = http://127.0.0.1:12900
rest_transport_uri = https://api.graylog.xxx.com/
web_endpoint_uri = https://graylog.xxx.com/
Web listen uri is left untouched. As per the server logs, Graylog bounds web and REST as desired:
[JerseyService] Started REST API at <http://127.0.0.1:12900/>
[JerseyService] Started Web Interface at <http://127.0.0.1:9000/>
But when I try to connect, in the webdev console, I can clearly see that there’s a problem:
"There was an error fetching a resource: cannot GET https://graylog.xxx.com/system/sessions (404)." Additional information: HTTP 404 Not Found
Shouldn’t that url belong to the api by the way?
web_endpoint_uri has to point to the public URI of the Graylog REST API, not to the URI of the Graylog web interface:
Additionally, your rest_transport_uri should be the same as rest_listen_uri (which is the default) if you’re using a reverse proxy.
Oh, that works, thank you very much. I hadn’t understood that web_endpoint_uri should be the api url and not the web interface.
