Issue with Nginx and graylog
Hello dear community,
I’m setting up a graylog as a demo server for my company.
I first tested the thing with no reverse proxy and with the following configuration in server.conf
rest_listen_uri = my lan ip:9000/api
web_listen_uri = my lan ip:9000/
It worked like a charm.
I wanted something more complex : separate api and web ports, and use nginx.
I switched to this :
Nginx :
server
    listen 80 default_server;
    server_name 192.168.41.68;
access_log      /var/log/nginx/graylog.access.log;
location / {
        proxy_set_header X-Graylog-Server-URL http://192.168.41.68/api;
        proxy_pass http://127.0.0.1:9000;
location /api/ {
        proxy_pass http://127.0.0.1:12900/;
and this in server.conf : web_listen_uri and web_endpoint_uri commented.
rest_listen_uri = http://127.0.0.1:12900/api/
rest_transport_uri = http://192.168.41.68:12900/api/
I get a 404 :
Error message
cannot GET http://192.168.41.68/api/ (404)
I’m out of ideas … Do you have something in mind ?
I would recommend the following Documentation:
http://docs.graylog.org/en/2.4/pages/configuration/web_interface.html#making-the-web-interface-work-with-load-balancers-proxies
Why not using your very first settings with nginx?
I kept the same nginx settings and followed your advice.
except for this in nginx :
location /api/ {
        proxy_pass http://127.0.0.1:9000/;
I used this :
rest_listen_uri = 127.0.0.1:9000/api
web_listen_uri = 127.0.0.1:9000/
Im getting a 404 but I’m allowed to get to the login page and try to login :slight_smile:
error :
Error - the server returned: 404 - cannot POST http://192.168.41.68/api/system/sessions (404)
Ok this is solved by using your recommendations but what I wanted was to be able to use nginx and differents ports for interface and api.
Whatever works : it is a demo after all.
Thank you
