Apologies if this is very basic.
I’m struggling to get my graylog running corectly with nginx proxy.
I want to access graylog from my headless server.
My setup is as follow:
graylog server.conf
rest_listen_uri =127.0.0.1:9000/api/
web_listen_uri =127.0.0.1:9000/
HTTP included as I can’t post it.
My nginx setup is exactly as the guide:
web_interface.html#webif-connecting-to-server
I’m receiving a error were once graylog opens, it gives an issue that can’t access http://127.0.0.1/api/
jan
(Jan Doberstein)
August 20, 2018, 4:42pm
2
you might have only one setting that is not working correctly
server
listen 80 default_server;
listen [::]:80 default_server ipv6only=on;
server_name graylog.example.org;
location / {
proxy_set_header X-Graylog-Server-URL http://$server_name/api;
proxy_pass http://127.0.0.1:9000;
the above configuration need to be on the Graylog server where the NGINX is running too. The server_name need to be set to the FQDN and if you connect to an IP and not the Hostname you need to adjust the line with X-Graylog-Server-URL and remove $server_name and place the IP in that.
Thank you so much JAN!! It works!
I’ve changed the X-Graylog-Server-URL to my local IP and we are in business!
