Graylog with NGINX
i installed a new ubuntu server with graylog and nginx according to instructions. Install went fine but i cannot use the nginx as a proxy.
Graylog work well if i configure http_bind_address to the ip of the server. When configure to localhost and use nginx to redirect i cannot log-in.
I see a error-message “Could not load stream - Loading streams failed with status: Fetch Error: There was an error fetching a resource: Unauthorized. Additional information: Not available”
I see following Error in chrome Developer:Tool
Request URL:http://graylog.domain.de/api/system/sessions
Request Method:
POST
Status Code:
401 Unauthorized
Remote Address:
172.x.x.x:80
Referrer Policy:
strict-origin-when-cross-origin
  • OS Information: Ubuntu 22.04.4
  • Package Version: graylog-server 6.0.0-14
    nginx 1.18.0-6ubuntu14.4
    Installed all according instructions
I only change the http_bind_address from 127.0.0.1:9000 to the ip:9000. It should be a nginx problem.
server
listen 80 default_server;
listen [::]:80 default_server;
server_name graylog.domain.de;
location / {
  proxy_set_header X-Graylog-Server-URL https://$server_name/;
  proxy_pass http://127.0.0.1:9000;
Hope you can give me a hint to solve the problem
Only the login process does not work. If I configure the graylog server with an IP and not with localhost and thus bypass the proxy, the login works. If I now configure everything back again and use the proxy again, graylog works as long as I remain logged in.
