Why messages does not go to stream
I created below stream( stream name is aaa )
  • source match exactly 10.98.0.2
  • level greater than 5
and it shows 8 messages/s go to this stream as below picture
but when I click this stream and go into it , it shows “Nothing found in stream aaa”
who can help me?
is the content of that stream visible when you select “show all messages” ?
Maybe the timestamp is not proper set.
no there isn’t any messages in when select “show all messages”
I think timestamp is OK, because I can search them in INPUTS and Default message stream
I try to define the params of stream_processing_timeout & stream_processing_max_faults ,and restart the graylog-server, now streams is OK…let me watch for a while
Find a message manually which according to you would match and try to “load message” in order to verify your stream rules. I guess it could be due to type mismatch in level (string vs int).
