Issue with pipeline and stream not seeing messages the are being received
Input being received, messages are being seen in input.
I created an index for it as well as a stream, then created a pipeline rule to filter the incoming input id and send it to the stream id. I have done this with two other inputs and both are working but this one doesn’t show the messages in the stream.
  • OS Information:
  • Ubuntu 22.04
  • Timezones set to UTC
  • Package Version:
    Graylog open 6.1.12
    Pipeline rule
rule "Move WLC Logs To WLC Stream"
  from_input(id: "6849696912a8694b9f320e8a")
  route_to_stream(id: "6849782812a8694b9f32bb34", remove_from_default: true);
Already built 2 other inputs, indexes, streams and pipeline using the same rule ( changing the id’s) and they both work, I have completely deleted this rule, pipeline, index and stream and recreated and still the same issue.
Any ideas what I am missing and why the messages are not coming through to the stream, I can see the messages being processed by the pipeline and when I look at a message directly from the input it states that it is being routed to the correct stream. I can also see the throughput on the stream screen showing message coming into the stream.
Just created a completely new input from a different device, new index, stream and pipeline and these messages are not coming through either. The in/out buffer is maxing about 20. No idea what I am doing wrong when the first 2 worked without issue
Time zone issue? If messages are being routed successfully, then the problem must be related to how you are searching for the messages.
