Hi Guys,
I saw the message was route to stream.
But when I choice the stream and click search nothing will show ?
Hi Guys,
Please post the actual stream rules and an example message that should be caught by it.
It is also possible that the timestamp on the message is off, such as a different time zone from the console viewing you are doing.
@tmacgbay
Thanks for your reply.
You could try using regex there
Message must match regular expression: ^kind\:s7
where the ^ enforces beginning of message and the \ next to the colon escapes it to be exact.
@tmacgbay
But the system was show “This message would be routed to this stream!”
As I know, that mean the rule is correct.
Am I right ?
What happens when you adjust the Search time? Maybe something beyond 5 minutes.
I also noticed that the time in the Message does not match the "timestamp " field. perhaps insure the Date/time ( & timezone) is correct. Not only on the server but the user and remote devices also has the correct timezone.
