Why is the installation guide so confusing?
Assume im not familiar with Graylog. Simplest setup - single node, ubuntu 22.04.4 LTS
I have trouble starting the most basic Graylog config, doc is confusing.
  1. How can i know which Graylog version i should choose? Not a word on this in the guide Installing Graylog
  2. How do i know which version of Opensearch to install (and what is actually Opensearch)? Point 5 of the Opensearch installation only provides command how to list the versions available for installation but provide no tips how to choose the proper ones (will all work?)
  3. The guide does not list commands for downloading proper version of Opensearch and setting default password (which i understand is needed later on to give Graylog connection to opensearch).
  4. In result of all this im stuck at
2024-04-29T01:32:52.681Z INFO  [VersionProbe] OpenSearch/Elasticsearch is not available. Retry #219
2024-04-29T01:32:57.683Z ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused.
2024-04-29T01:32:57.683Z INFO  [VersionProbe] OpenSearch/Elasticsearch is not available. Retry #220
would appreciate help and improvements to the guide for Graylog newbies. Around 2-3 years ago i succesfully used the guide to start graylog. Now i am unable to do that.
opensearch apparently not running
× opensearch.service - Opensearch
     Loaded: loaded (/etc/systemd/system/opensearch.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Mon 2024-04-29 01:21:54 UTC; 15min ago
       Docs: https://opensearch.org/docs/latest
    Process: 228899 ExecStart=/graylog/opensearch/bin/opensearch (code=exited, status=1/FAILURE)
   Main PID: 228899 (code=exited, status=1/FAILURE)
        CPU: 9.365s
Apr 29 01:21:54 graylog opensearch[228899]:         at org.opensearch.bootstrap.OpenSearch.execute(OpenSearch.java:171)
Apr 29 01:21:54 graylog opensearch[228899]:         at org.opensearch.cli.EnvironmentAwareCommand.execute(EnvironmentAw>
Apr 29 01:21:54 graylog opensearch[228899]:         at org.opensearch.cli.Command.mainWithoutErrorHandling(Command.java>
Apr 29 01:21:54 graylog opensearch[228899]:         at org.opensearch.cli.Command.main(Command.java:101)
Apr 29 01:21:54 graylog opensearch[228899]:         at org.opensearch.bootstrap.OpenSearch.main(OpenSearch.java:137)
Apr 29 01:21:54 graylog opensearch[228899]:         at org.opensearch.bootstrap.OpenSearch.main(OpenSearch.java:103)
Apr 29 01:21:54 graylog opensearch[228899]: For complete error details, refer to the log at /var/log/opensearch/graylog>
Apr 29 01:21:54 graylog systemd[1]: opensearch.service: Main process exited, code=exited, status=1/FAILURE
Apr 29 01:21:54 graylog systemd[1]: opensearch.service: Failed with result 'exit-code'.
Apr 29 01:21:54 graylog systemd[1]: opensearch.service: Consumed 9.365s CPU time.
 tail -f /var/log/opensearch/graylog.log
        at org.opensearch.plugins.PluginsService.loadBundle(PluginsService.java:730) ~[opensearch-2.0.1.jar:2.0.1]
        at org.opensearch.plugins.PluginsService.loadBundles(PluginsService.java:532) ~[opensearch-2.0.1.jar:2.0.1]
        at org.opensearch.plugins.PluginsService.<init>(PluginsService.java:195) ~[opensearch-2.0.1.jar:2.0.1]
        at org.opensearch.node.Node.<init>(Node.java:413) ~[opensearch-2.0.1.jar:2.0.1]
        at org.opensearch.node.Node.<init>(Node.java:336) ~[opensearch-2.0.1.jar:2.0.1]
        at org.opensearch.bootstrap.Bootstrap$5.<init>(Bootstrap.java:244) ~[opensearch-2.0.1.jar:2.0.1]
        at org.opensearch.bootstrap.Bootstrap.setup(Bootstrap.java:244) ~[opensearch-2.0.1.jar:2.0.1]
        at org.opensearch.bootstrap.Bootstrap.init(Bootstrap.java:414) ~[opensearch-2.0.1.jar:2.0.1]
        at org.opensearch.bootstrap.OpenSearch.init(OpenSearch.java:180) ~[opensearch-2.0.1.jar:2.0.1]
        ... 6 more
  1. It seems like this is a brand new install - just install the most recent version.
  2. The guide says Opensearch 1.x or 2.x. I would install the most recent Opensearch 2.x. I’m on Elastic myself and probably need to migrate.
  3. Please check again on this page: Ubuntu Installation
