What changes are needed for fresh graylog 5. installation to enable opensearch / disable elasticsearch
I successfully installed opensearch for a fresh Graylog 5 Open.
If i try to run graylog i get a lots off errors that elasticsearch is not installed.
server.log
2023-01-03T10:39:09.695Z ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused.
2023-01-03T10:39:09.695Z INFO [VersionProbe] Elasticsearch is not available. Retry #241
i tried to find something in the server.conf to disable elasticsearch and to enable opensearch but so far no luck.
can anybody point me in the right direction where / how i can enable opensearch for graylog ?
System:
Linux Ubuntu 22.04
Graylog 5
could just solve that Problem my self:
opensearch.yml
the line
network.host: ${HOSTNAME}
must be:
network.host: 127.0.0.1
in my installation because i have no working DNS i guess :slight_smile:
now my first Graylog 5.x is up and running
Hey @Matthias23
I assume this is resolved? if so could you mark this as resolved for future searchs.
