Valid metadata Not Found at specific URL
I tried to install GRAYLOG. First several times I kept receiving an error when trying to import the keyring.gpg. Next, I tried the solution offered as a work around from a previous post mentioning there was a problem with the keyring. The result of the workaround attempt I received : Valid metadata not found a specified URL.
  • OS Information: SuSE
  • Package Version:
    SP5
    There are none log wise. No real config as I haven’t gotten that far.
I have trashed a number of virtual machines (VMware 8), after installing all the other requirements like Mongodb, Opensearch.
I would like to know if anyone ever got this to work install wise (Graylog-5.0.1) or do I need to throw in the towel and move on to another package like Elastic or the like.
hi @mongoose
It would be helpful to post the precise error messages here - otherwise it will be difficult to help you.
Presently the following issue received when I found that the original approach listed in documents was wrong with respect to gpg keys:
I did post the info you asked for a bit ago.
sorry, I don’t know an answer. maybe @gsmith can help?
I appreciate the help.
Hey @mongoose
From your screenshot your RPm doesnt look right. Should be something like this
rpm --import https://packages.graylog2.org/repo/debian/keyring.gpg
Then add the repository file /etc/zypp/repos.d/graylog.repo with the following
content:
[graylog]
name=graylog
baseurl=https://packages.graylog2.org/repo/el/stable/5.0/$basearch/
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-graylog
After that, install the latest Graylog Open release with:
sudo zypper install graylog-server
OR
sudo zypper install graylog-enterprise
