Upgraded from 2.4 to 2.5, still running 2.4 after restart
I just upgraded from 2.4 to 2.5 using the deb repository and upgrade docs. Everything seemed to go fine, but when I either issue a systemctl restart or reboot the server, it still comes back up running the older 2.4.6 version. How can I get it to switch over to 2.5?
Thanks!
He
did you reload your browser? It can happen that if you leave your browser window open during the update and the reboot and did not do a “full reload” of the page it looks like you have not updated.
What can you see in your Graylog server.log? Graylog is writing it’s version to the logfile.
Jan
Hi Jan,
Reloading my browser did it, I should’ve tried that before posting. Thank you!
Dear @rhp, Could you please check the /usr/share/graylog-server/plugin/ folders. Maybe we can see if the graylog has been updated properly then you will get the updated plugins like graylog-plugin-threatintel-2.5.0.jar. This is also one option from CLI.
