Dear all,
we run a Graylog Instance (4.3.15) with OpenSearch 1.3.12 and MongoDB 5.0.21. Everything is fine. This is a Enterprise Instance with a an outdated license (fall back to open source license).
user7@sles_server:~> rpm -qa | grep graylog
graylog-enterprise-plugins-4.3.15-1.x86_64
graylog-integrations-plugins-4.3.15-1.noarch
graylog-enterprise-integrations-plugins-4.3.15-1.noarch
graylog-server-4.3.15-1.noarch
In Graylog 5 we don’t have those listed packages anymore. Instead, there ist just the Enterprise package graylog-enterprise-5.0.10-1.x86_64.rpm or the Open package graylog-server-5.0.10-1.x86_64.rpm
What package do you recommend to install? Server or Enterprise?
The instance for now will run without Enterprise license, but will probably get in future a new Enterprise license.
Thanks in advance for the help.
Regards,
Dietmar Schurr
OS: SLES 12 SP5 (will be upgrade to SLES 15)
