Hi All,
Getting unexpected error during stream matching in my logs continuously. Not able to understand the logs. how can I know which stream is the culprit?
2018-10-03T18:12:27.454Z WARN [StreamRouterEngine] Unexpected error during stream matching
java.util.concurrent.TimeoutException: null
at java.util.concurrent.FutureTask.get(FutureTask.java:205) ~[?:1.8.0_141]
at com.google.common.util.concurrent.SimpleTimeLimiter.callWithTimeout(SimpleTimeLimiter.java:147) ~[graylog.jar:?]
at org.graylog2.streams.StreamRouterEngine$Rule.matchWithTimeOut(StreamRouterEngine.java:303) [graylog.jar:?]
at org.graylog2.streams.StreamRouterEngine$Rule.access$000(StreamRouterEngine.java:264) [graylog.jar:?]
at org.graylog2.streams.StreamRouterEngine.match(StreamRouterEngine.java:191) [graylog.jar:?]
at org.graylog2.streams.StreamRouter.route(StreamRouter.java:99) [graylog.jar:?]
at org.graylog2.filters.StreamMatcherFilter.filter(StreamMatcherFilter.java:42) [graylog.jar:?]
at org.graylog2.messageprocessors.MessageFilterChainProcessor.process(MessageFilterChainProcessor.java:100) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.handleMessage(ProcessBufferProcessor.java:114) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.dispatchMessage(ProcessBufferProcessor.java:100) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:77) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:42) [graylog.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_141]
2018-10-03T18:16:18.430Z WARN [StreamRouterEngine] Unexpected error during stream matching
