Strange issue with a stream
Have configured UDP logs from our watchguard firewall. I can see the messages coming in on the input.
I have configured a stream matching the Gl2_source_input.
When finding a message it says its routed into a stream and is going into an index.
However if i go in via the stream there are no results.
All my other streams are working, its also not in the default stream (check box selected to stop that)
Any ideas?
  • OS Information:Ubuntu 24.04
  • Package Version:6.3.3
Recreated the stream, cant think what else to do
Did you “start” the stream or is it paused? you can see from the streams page that lists them all. That has bit me several times.
Yeah the stream is started as i can see other firewall entries in there. Just not the one one specific one. I loaded an example message and the rules match. not sure why this is happening
@Rick Could it be these messages are arriving with a timestamp that is either in the future or the past due to an unexpected timezone?
