I am getting the error ‘Something went wrong’ periodically and I can’t seem to find any correlation or log. No matter what I am doing in the web UI (typically editing Pipeline Rules or correlating events) but it doesn’t seem to matter. In fact, the UI could be doing nothing and then it will switch to the error message.
This is the ‘Show More’ value and I can’t seem to decipher it (replaced my console with console.my.fqdn )
Reduce of empty array with no initial value
Stack Trace:
TypeError: Reduce of empty array with no initial value
at Array.reduce (<anonymous>)
at b.render (http://console.my.fqdn/assets/5c4b4521-1.a5e2fb591e8fd54ee4ef.js:1:14484)
at ct (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:18:59598)
at zt (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:18:59393)
at it (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:18:63066)
at Vt (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:18:78129)
at Ut (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:18:78506)
at Tn (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:18:84899)
at gn (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:18:84286)
at Rn (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:18:83307)
at $t (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:18:82227)
at Object.enqueueSetState (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:18:47300)
at b.W.setState (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:26:1660)
at M.e (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:10:1321)
at M.emit (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:82:1058853)
at n.trigger (http://console.my.fqdn/assets/vendor.4024e2a8db732781a971.js:10:2196)
at http://console.my.fqdn/assets/builtins.a5e2fb591e8fd54ee4ef.js:158:109610
at a (http://console.my.fqdn/assets/builtins.a5e2fb591e8fd54ee4ef.js:158:88318)
at A._settlePromiseFromHandler (http://console.my.fqdn/assets/builtins.a5e2fb591e8fd54ee4ef.js:158:61004)
at A._settlePromise (http://console.my.fqdn/assets/builtins.a5e2fb591e8fd54ee4ef.js:158:61887)
at A._settlePromise0 (http://console.my.fqdn/assets/builtins.a5e2fb591e8fd54ee4ef.js:158:62627)
at A._settlePromises (http://console.my.fqdn/assets/builtins.a5e2fb591e8fd54ee4ef.js:158:63970)
at http://console.my.fqdn/assets/builtins.a5e2fb591e8fd54ee4ef.js:158:16848
Component Stack:
in MetricContainer
in dd
in dl
in div
in p
in div
in p
in div
in t
in div
in Pipeline
in div
in p
in div
in p
in div
in i
in PipelineDetailsPage
in n
in div
in p
in div
in p
in div
in t
in div
in t
in n
in withRouter(n)
in div
in App
in RouterContext
in Router
in h
in t
in n
in AppFacade
I also have this error in logs which I am unable to locate the source for and may or may not be related:
2019-07-15T15:07:02.951Z WARN [StreamRouterEngine] Unexpected error during stream matching
java.util.concurrent.TimeoutException: null
at java.util.concurrent.FutureTask.get(FutureTask.java:205) ~[?:1.8.0_212]
at com.google.common.util.concurrent.SimpleTimeLimiter.callWithTimeout(SimpleTimeLimiter.java:156) ~[graylog.jar:?]
at org.graylog2.streams.StreamRouterEngine$Rule.matchWithTimeOut(StreamRouterEngine.java:307) [graylog.jar:?]
at org.graylog2.streams.StreamRouterEngine$Rule.access$000(StreamRouterEngine.java:264) [graylog.jar:?]
at org.graylog2.streams.StreamRouterEngine.match(StreamRouterEngine.java:191) [graylog.jar:?]
at org.graylog2.streams.StreamRouter.route(StreamRouter.java:99) [graylog.jar:?]
at org.graylog2.filters.StreamMatcherFilter.filter(StreamMatcherFilter.java:42) [graylog.jar:?]
at org.graylog2.messageprocessors.MessageFilterChainProcessor.process(MessageFilterChainProcessor.java:100) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.handleMessage(ProcessBufferProcessor.java:114) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.dispatchMessage(ProcessBufferProcessor.java:100) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:77) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:42) [graylog.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_212]
