Unable to upgrade using yum or dnf
sudo dnf upgrade graylog
graylog 366 B/s | 406 B 00:01
graylog 916 kB/s | 938 B 00:00
graylog 396 B/s | 406 B 00:01
Errors during downloading metadata for repository ‘graylog’:
  • Status code: 404 for ://packages.graylog2.org/repo/el/stable/4.3/x86_64/repodata/repomd.xml.asc (IP: 54.91.6.89)
  • Status code: 404 for ://packages.graylog2.org/repo/el/stable/4.3/x86_64/repodata/repomd.xml.asc (IP: 54.196.16.164)
    Error: Failed to download metadata for repo ‘graylog’: GPG verification is enabled, but GPG signature is not available. This may be an error or the repository does not support GPG verification: Status code: 404 for ://packages.graylog2.org/repo/el/stable/4.3/x86_64/repodata/repomd.xml.asc (IP: 54.196.16.164)
  • OS Information: Rocky Linux release 9.0 (Blue Onyx)
  • Package Version: 4.3
    sudo cat /etc/yum.repos.d/graylog.repo
[graylog]
name=graylog
baseurl=https://packages.graylog2.org/repo/el/stable/4.3/$basearch/
gpgcheck=1
repo_gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-graylog
Have tried making edits to the repos file
have tried:
sudo dnf clean packages
sudo rpm --rebuilddb -v
sudo dnf update --refresh
Hey @MK2022
Since this is red hat fork you should be able to use YUM
yum update
sudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-4.3-repository_latest.rpm
sudo yum install graylog-server graylog-enterprise-plugins graylog-integrations-plugins graylog-enterprise-integrations-plugins
This is the documentation needed for installing here
Thank you for your suggestion. Unfortunately, this does not work, to wit:
sudo yum update
[sudo] password for @:
graylog 265 B/s | 406 B 00:01
graylog 377 B/s | 406 B 00:01
sudo rpm -Uvh ://packages.graylog2.org/repo/packages/graylog-4.3-repository_latest.rpm
Retrieving ://packages.graylog2.org/repo/packages/graylog-4.3-repository_latest.rpm
error: /var/tmp/rpm-tmp.FvFjmT: Header V4 RSA/SHA1 Signature, key ID b1606f22: BAD
error: /var/tmp/rpm-tmp.FvFjmT cannot be installed
graylog 361 B/s | 406 B 00:01
graylog 387 B/s | 406 B 00:01
Please let me know if there are any other commands to try.
Hey @MK2022
You have something funky going on with your system.
Try cleaning your repo for graylog, perhaps also do a root # yum clean all
Just make sure your old Graylog-Repo is gone.
Then try it again.
yum update
NOTE: by chance did you execute root # yum install epel-release?
@MK2022
Took some time to make it simple for ya.
Steps
  • list all your repos
root # yum repolist
  • Remove Graylog repo and ensure you put the correct full name. Below is an example.
root # yum remove graylog*
  • Check repo directory to ensure it clean.
root # ls  -al /etc/yum.repos.d/
NOTE: If you still see your Graylog repo then force remove it. Two ways to do this, use the full path or enter the repoistory and remove it from there.
root # rm -rf  /etc/yum.repos.d/graylog*
  • Even thou Graylog repo is/was deleted run.
Then run the following.
root # yum update
root # sudo rpm -Uvh https://packages.graylog2.org/repo/packages/graylog-4.3-repository_latest.rpm
root # sudo yum install graylog-server graylog-enterprise-plugins graylog-integrations-plugins graylog-enterprise-integrations-plugins
Hope it helps.
