Un-released plug-in
I would like to use a plug-in(https://github.com/rswestmoreland/graylog-delimited-file-output-plugin) that I found on Graylog market place, but there’s no release on the Github. Why is it showing up in the marketplace ? Can I try to compile my-self using maven and use it ?
While they aren’t exactly exhaustive, the project does have build instructions: https://github.com/rswestmoreland/graylog-delimited-file-output-plugin#how-to-build
You can also try filing an issue in the GitHub repository you’ve mentioned.
