Are there updated docs on how to create a plugin somewhere?
Hi There,
I was attempting to create a plugin for graylog, and had some issues with the documentation here: http://docs.graylog.org/en/latest/pages/plugins.html
It’s telling me after I clone the graylog-project.git I should run $ scripts/bootstrap but that doesn’t exist.
Following the instructions on the graylog-project github project I got the graylog-project-cli from github and ran this instead
graylog-project bootstrap --manifest=“manifests/2.4.json” github://Graylog2/graylog-project.git
but now I’m wondering if there’s a way that I can do the equivalent of what the docs are telling me to do here:
scripts/bootstrap-plugin jira-alarmcallback
What I’ve done for now is cd to graylog-project-repos
git clone git@github.com:Graylog2/graylog-plugin-sample.git
But it looks like a LOT of search and rename, as well as moving files around will be required to modify this plugin to be it’s own entity.
Is this the recommended workflow?
Heyo,
the closest to up-to-date would probably be something like this:
Greetings,
Philipp
I saw that, and it was helpful for getting the right branch set up with the bootstrap but it doesn’t actually detail bootstrapping a plugin at all.
The sample plugin does build there, but I’m not entirely sure everything I have to rename to get it to build my own plugin.jar
incidentally if someone does try bootstrapping but doesn’t specify the branch, then building the sample plugin does not work. for some reason you need to actually install yarn on the system. ( it seems like one of the scripts doesn’t reference yarn properly ) and you need to override which version of node is downloaded in the sample plugins pom.xml
in case anyone else was trying to write a plugin, here are some resources that I found helpful.
( basically this says, after you’ve bootstrapped graylog, if you want to compile your plugin without compiling graylog, you should run “mvn generate-resources” in the graylog-project-repos/graylog-project folder )
How to hook your plugin into graylog
if your plugin depends on graylog, then you need to set isolated=false in your graylog-plugin.properties file
