Tomcat timestamp parsing problem
I am parsing Tomcat JSON Logs via a pipeline rule like this:
set_fields(to_map(parse_json(to_string($message.message))));
which works fine, except that doesnt parse the timestamp format. instead i get a error message like this:
Replaced invalid timestamp value in message <56e712d1-4b04-11ed-b292-566f4f06005b> with current time - Value <Thu Oct 13 16:35:52 CEST 2022> caused exception: Invalid format: “Thu Oct 13 16:35:52 CEST 2022”
Maybe someone has a hint how i can fix/workaround this in my pipeline?
Cheers :slight_smile:
Hello @irq1337
This is common issue in the forum and there are a few resolves depending how and what was configured. We would need more information to help us, help you.
Example:
I came across this…
