Struggling With Timestamp conversion
We are receiving processing errors for 2 different log sources relating to timestamps.
Failure Details Example:
Value <2024-08-22T17:55:22.875418Z> caused exception: Invalid format: “2024-08-22T17:55:22.875418Z” is malformed at “T17:55:22.875418Z”.
2 node cluster in Graylog Cloud of 6.0.4
I have attempted to do research onto how other people have solved this issue.
I found pipeline rules extracting/parsing the timestamp to be the solution for most people but its just not working for me.
Here is the current pipeline rule I am trying out, doesn’t seem to work:
rule "testing timestamps"
   true
    let result = regex("([0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}:[0-9]{2}.[0-9]{3})",to_string($message.message));
    let new_date = parse_date(to_string(result["0"]), "yyyy-MM-dd'T'HH:mm:ss.SSS","EST");
    set_field("timestamp", new_date);
This doesn’t appear to set the new date correctly:
The regex appears to be good.
I have also played around with the date format in new_date trying different variations. Where am I going wrong? For what its worth, I’m pretty new to pipeline rules so it might be painfully obvious what I’m doing wrong to you guys.
Looking for a bit of guidance on next steps.
I think I found something that works.
rule "Fix Timestamp"
   has_field("timestamp")
    let result = regex("([0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}:[0-9]{2}.[0-9]{3})",to_string($message.timestamp));
    let new_date = parse_date(to_string(result["0"]), "yyyy-MM-dd'T'HH:mm:ss.SSS", "America/Toronto");
I swear I had already tried this but guess not…
Gonna let it soak over night.
hey @EyImWawkinHeah
If that doesn’t work, try setting the field “timestamp” to “timestamp1”.
That’s essentially how I found out my stuff wasn’t working, thanks for the response!
