I can’t make TLSSKIPVERIFY key work when i install sidecar on Windows.
Config is simple:
graylog_sidecar_installer_1.5.0-1.exe /S -SERVERURL=https://graylogserver/api -TLSSKIPVERIFY=true -TAGS=["windows"] -APITOKEN=apitoken
and all the keys applies, but “tls_skip_verify” is always false in config file.
How debug it?
cesq
2
Hi, try TLS_SKIP_VERIFY.
I checked it by looking at all the silent install options in the source code of the installer
Here are all the options:
; Parse command line options
; The first character in the option string is treated as a parameter delimiter, so we prepend a white-space
; to allow options like -NODENAME=my-collector (second dash would interrupt option parsing otherwise)
${GetParameters} $Params
${GetOptions} $Params " -SERVERURL=" $ParamServerUrl
${GetOptions} $Params " -NODENAME=" $ParamNodeName
${GetOptions} $Params " -UPDATE_INTERVAL=" $ParamUpdateInterval
${GetOptions} $Params " -TLS_SKIP_VERIFY=" $ParamTlsSkipVerify
${GetOptions} $Params " -SEND_STATUS=" $ParamSendStatus
${GetOptions} $Params " -APITOKEN=" $ParamApiToken
${GetOptions} $Params " -NODEID=" $ParamNodeId
${GetOptions} $Params " -TAGS=" $ParamTags
Found here → collector-sidecar/dist/recipe.nsi at master · Graylog2/collector-sidecar · GitHub
Recommended by this post → Windows Collector Sidecar Install Switches
Yes, it works. Thank you very much.
