Sidecars won't work after setting up https
I recently added a self signed certificate for https to my Graylog server using the Graylog docs ( Using HTTPS — Graylog 4.0.0 documentation ). After that my Sidecars stopped showing up on the web interface. So I edited the config to:
output.logstash:
   hosts: ["https://192.168.***.***:5044"]
Now the status of my sidecars says “running”. But they wont send any logs.
-----CONFIGS----
I didn’t change much but here they are.
-Winlogbeat Collector Configuration
# Needed for Graylog
fields_under_root: true
output.logstash:
path:
tags:
 - windows
winlogbeat:
  event_logs:
   - name: Application
   - name: System
   - name: Security
-INPUT for winlogbeat
    bind_address: 0.0.0.0
    no_beats_prefix: false
    number_worker_threads:4
    override_source:<empty>
    port: 5044
    recv_buffer_size:1048576
    tcp_keepalive: false
    tls_cert_file: /etc/graylog/cert.pem
    tls_client_auth: disabled
    tls_client_auth_cert_file:  <empty>
    tls_enable: true
    tls_key_file: /etc/graylog/pkcs8-encrypted.pem
    tls_key_password: ********
I also get that error message in my graylog server log:
Thank you in advance!
I should have mentioned that I worked myself through many configs for my collectors.
Even with ssl.enabled: true verification_mode: none my sidecars won’t send logs to Graylog. Or might it be an issue with elasticsearch?
Do I have to add my self signed cert to my Sidecar configuration? (See Configure SSL | Filebeat Reference [7.13] | Elastic )
Hello
I just started using Beats ( winlogbeat, metricbeat, etc…)
I’m not sure about sidecar in graylog but I do know for my winlogbeat I did have to add my cert’s
It’s not filebeat but I did have to add certs to connect to my INPUT on graylog.
output.logstash:
  hosts: ["https://elastic-stack.enseva-labs.net:5044"]
  username: "admin"
  password: "admin"
  server.ssl.enabled: true
  ssl.certificate_authorities: 'C:\Program Files\winlogbeat\root-ca.pem'
  server.ssl.certificate: 'C:\Program Files\winlogbeat\admin.pem'
  server.ssl.key: 'C:\Program Files\winlogbeat\admin-key.pem'
Hope that helps
Hi gsmith,
was missing on my end here. Thank you so much!
