Hello GL community,
I have a little sandbox GL3.0 instance which is successfully ingesting events from a sidecar (1.0) using beats.
I can enable TLS on the beats input, and it assigns the autoconfigured self-signed cert which I verified using curl, but I can’t figure out the beats output lines to set in the sidecar-pushed config…
I’ve read http://docs.graylog.org/en/3.0/pages/sidecar.html#secure-sidecar-communication, but I cannot for the life of me figure out how to "just mark Enable TLS Support and Insecure TLS connection". I’ve tried various snippets from elastic’s website with no luck. I would appreciate any guidance or clarification on the matter. Thanks again GL community!
Respectfully,
/nadmin
My blank sidecar config:
# Needed for Graylog
fields_under_root: true
output.logstash:
hosts: ["logserver.fqdn:5044"]
path:
tags:
- windows
winlogbeat:
event_logs:
- name: Microsoft-Windows-Sysmon/Operational
- name: Security
