Threat Intel 2.3.0 Compatibility
I have tried to get the TI plugin working with Graylog 2.3.0.
Currently I used wget to download the .jar of the plugin to /usr/share/graylog-server/plugin and then changed the permissions with chmod 644 and then restarted the Graylog service. These steps have worked in previous Graylog versions so I was just wondering if the TI plugin is compatible as I couldn’t see anything on the Github page.
Regards,
G
I got the same problem !!
When I use mongodb profiler and slack plugin for new cluster version 2.3, they dont work!
Any update for them ?
