Hello everyone.
I have created graylog cluster with 2 nodes(4.2.11v) behind nginx with load balancer. Of course mongo and ES clusters too. But i have the same statistics on two nodes graylog.
As i know each node mush have different messages statistics or not?
Looks good to me that heap seams a little high, but I don’t know how much log you ingesting per second. Did you check the logs on all of the nodes to insure there wasn’t a issue?
If this is a lab setup, you could do a control test by shutting one Graylog server down and your setup should be functioning, especially with nginx as a load balancer, Just a thought. I would not do this on production servers.
