System information is currently unavailable - Timeout Issues
I am getting the below issue in my nodes page. I currently run 1 node with everything on it. I do not go through a proxy.
Looking through the log shows a lot of:
2021-05-11T16:54:26.287-04:00 WARN  [ProxiedResource] Unable to call https://172.16.8.214:9000/api/system/metrics/multiple on node <21ece229-31c0-4f6b-b1ec-d764c59a6488>: timeout
2021-05-11T16:54:36.348-04:00 WARN  [ProxiedResource] Unable to call https://172.16.8.214:9000/api/system/metrics/multiple on node <21ece229-31c0-4f6b-b1ec-d764c59a6488>: timeout
2021-05-11T16:54:40.230-04:00 WARN  [ProxiedResource] Unable to call https://172.16.8.214:9000/api/system on node <21ece229-31c0-4f6b-b1ec-d764c59a6488>: timeout
2021-05-11T16:54:52.243-04:00 WARN  [ProxiedResource] Unable to call https://172.16.8.214:9000/api/system/metrics/multiple on node <21ece229-31c0-4f6b-b1ec-d764c59a6488>: timeout
2021-05-11T16:54:52.258-04:00 WARN  [ProxiedResource] Unable to call https://172.16.8.214:9000/api/system on node <21ece229-31c0-4f6b-b1ec-d764c59a6488>: timeout
2021-05-11T16:55:02.328-04:00 WARN  [ProxiedResource] Unable to call https://172.16.8.214:9000/api/system/metrics/multiple on node <21ece229-31c0-4f6b-b1ec-d764c59a6488>: timeout
2021-05-11T16:55:04.323-04:00 WARN  [ProxiedResource] Unable to call https://172.16.8.214:9000/api/system on node <21ece229-31c0-4f6b-b1ec-d764c59a6488>: timeout
2021-05-11T16:55:14.334-04:00 WARN  [ProxiedResource] Unable to call https://172.16.8.214:9000/api/system/metrics/multiple on node <21ece229-31c0-4f6b-b1ec-d764c59a6488>: timeout
2021-05-11T16:55:16.247-04:00 WARN  [ProxiedResource] Unable to call https://172.16.8.214:9000/api/system on node <21ece229-31c0-4f6b-b1ec-d764c59a6488>: timeout
2021-05-11T16:55:24.408-04:00 WARN  [ProxiedResource] Unable to call https://172.16.8.214:9000/api/system/metrics/multiple on node <21ece229-31c0-4f6b-b1ec-d764c59a6488>: timeout
Below are what I believe are the relevant conf settings. I have tried with and with out specifying HTTPS.
http_bind_address = 172.16.8.214:9000
http_publish_uri = https://172.16.8.214:9000/
#http_external_uri =
From other troubleshooting I have found I ran the command :
$ curl -i ‘https://172.16.8.214:9000/api/?pretty=true
and get the output:
HTTP/1.1 307 Temporary Redirect
X-Graylog-Node-ID: 21ece229-31c0-4f6b-b1ec-d764c59a6488
X-Runtime-Microseconds: 223
Content-Length: 0
Any ideas on what else to try or check?
What does your service status look like.
systemctl status elasticsearch
Does you elasticsearch.yaml configuration network.host: match your graylog confguration file configuration elasticsearch_hosts = ?
Any firewalls enabled on your server?
EDIT: Try this and see what you get.
curl -i ‘http://172.16.8.214:9000/api/?pretty=true’
Since you stated your using HTTPS it may be your certificates. Try setting it back to HTTP and restart graylog service. In the past I have missed a configuration and my HTTP connection still didnt work.
Thank you @gsmith after testing it seems to be my certificates. It was working but it is around time to replace them anyway. Thank you!
