Error getting data(click system/node)
When I click on node to view information, Error getting data occurs
  • OS Information:
    Ubuntu 20.4
  • Package Version:
    5.1.2
    2023-06-16T17:43:50.677+08:00 WARN [ProxiedResource] Failed to call API on node <426509fb-b000-406d-be85-df4e73b7e20e>, cause: timeout (duration: 5003 ms)
    2023-06-16T17:43:55.436+08:00 WARN [ProxiedResource] Failed to call API on node <426509fb-b000-406d-be85-df4e73b7e20e>, cause: timeout (duration: 5001 ms)
    2023-06-16T17:43:55.690+08:00 WARN [ProxiedResource] Failed to call API on node <426509fb-b000-406d-be85-df4e73b7e20e>, cause: timeout (duration: 5002 ms)
    2023-06-16T17:44:00.462+08:00 WARN [ProxiedResource] Failed to call API on node <426509fb-b000-406d-be85-df4e73b7e20e>, cause: timeout (duration: 5002 ms)
    2023-06-16T17:44:00.704+08:00 WARN [ProxiedResource] Failed to call API on node <426509fb-b000-406d-be85-df4e73b7e20e>, cause: timeout (duration: 5002 ms)
    2023-06-16T17:44:05.446+08:00 WARN [ProxiedResource] Failed to call API on node <426509fb-b000-406d-be85-df4e73b7e20e>, cause: timeout (duration: 5002 ms)
    2023-06-16T17:44:05.717+08:00 WARN [ProxiedResource] Failed to call API on node <426509fb-b000-406d-be85-df4e73b7e20e>, cause: timeout (duration: 5002 ms)
    2023-06-16T17:44:10.457+08:00 WARN [ProxiedResource] Failed to call API on node <426509fb-b000-406d-be85-df4e73b7e20e>, cause: timeout (duration: 5001 ms)
2023-06-16T17:28:21.027+08:00 WARN [ProxiedResource] Failed to call API on node <426509fb-b000-406d-be85-df4e73b7e20e>, cause: timeout (duration: 5001 ms)
2023-06-16T17:28:23.833+08:00 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
java.io.InterruptedIOException: timeout
at okhttp3.internal.connection.Transmitter.timeoutExit(Transmitter.java:109) ~[graylog.jar:?]
at okhttp3.internal.connection.Transmitter.maybeReleaseConnection(Transmitter.java:302) ~[graylog.jar:?]
at okhttp3.internal.connection.Transmitter.noMoreExchanges(Transmitter.java:267) ~[graylog.jar:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:237) ~[graylog.jar:?]
at okhttp3.RealCall.execute(RealCall.java:81) ~[graylog.jar:?]
at retrofit2.OkHttpCall.execute(OkHttpCall.java:204) ~[graylog.jar:?]
at org.graylog2.rest.resources.cluster.ClusterSystemResource.jvm(ClusterSystemResource.java:90) ~[graylog.jar:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Unknown Source) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory.lambda$static$0(ResourceMethodInvocationHandlerFactory.java:52) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:134) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:177) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:219) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:81) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:478) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:400) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:81) ~[graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:255) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:292) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:274) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:244) [graylog.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:234) [graylog.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:684) [graylog.jar:?]
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:356) [graylog.jar:?]
at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:200) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
Use the recommended configuration on the official website
Restarting mongodb and es for multiple times cannot be resolved
help me everybody thank you very much
Hey @fader1
Can you show your configurations?
