I installed graylog and configured an input stream for syslog. There are constantly messages coming in (the in/out in the upper right shows incoming logs), but they are not shown up in the dashboard.
I found out that the timestamp of the messages could not be parsed. A example message and the corresponding error log is shown below. I searched a little bit around and found out that a Extractor could help.
Unfortunately, my configured extractor for the timestamp does not work, the error still occurs.
What I am doing wrong?
OS Information: Debian 12
Package Version:
ii graylog-6.1-repository 1-1 all Package to install Graylog 6.1 GPG key and repository
ii graylog-datanode 6.1.4-2 amd64 Graylog data node
ii graylog-server 6.1.4-2 amd64 Graylog server
ii mongodb-database-tools 100.10.0 amd64 mongodb-database-tools package provides tools for working with the MongoDB server:
ii mongodb-mongosh 2.3.6 amd64 MongoDB Shell CLI REPL Package
ii mongodb-org 7.0.15 amd64 MongoDB open source document-oriented database system (metapackage)
ii mongodb-org-database 7.0.15 amd64 MongoDB open source document-oriented database system (metapackage)
ii mongodb-org-database-tools-extra 7.0.15 amd64 Extra MongoDB database tools
ii mongodb-org-mongos 7.0.15 amd64 MongoDB sharded cluster query router
ii mongodb-org-server 7.0.15 amd64 MongoDB database server
ii mongodb-org-shell 7.0.15 amd64 MongoDB shell client
ii mongodb-org-tools 7.0.15 amd64 MongoDB tools
- Service logs, configurations, and environment variables:
Message:
B<7>1 2024-12-16T22:00:35.539770+1:00 zensored - - - 000+01:04:39.652 T 11318: zensored
syslog{"source":{"allow_override_date":true,"charset_name":"UTF-8","expand_structured_data":false,"force_rdns":false,"store_full_message":true,"timezone":"Europe/Berlin"}}2B
Log:
2024-12-16T22:06:07.215+01:00 ERROR [DecodingProcessor] Unable to decode raw message RawMessage{id=915df0e0-bbf1-11ef-bdbb-bc2411e87d7a, messageQueueId=238090, codec=syslog, payloadSize=102, timestamp=2024-12-16T22:00:35.540Z, seqenceNr=4343, remoteAddress=/192.168.2.254:49348} on input <675f3dc643368c1923874837>.
2024-12-16T22:06:07.233+01:00 ERROR [DecodingProcessor] Error processing message RawMessage{id=915df0e0-bbf1-11ef-bdbb-bc2411e87d7a, messageQueueId=238090, codec=syslog, payloadSize=102, timestamp=2024-12-16T22:00:35.540Z, seqenceNr=4343, remoteAddress=/192.168.2.254:49348}
java.lang.IllegalArgumentException: Invalid format: "2024-12-16T22:00:35.539770+1:00" is malformed at "+1:00"
at org.joda.time.format.DateTimeFormatter.parseDateTime(DateTimeFormatter.java:953) ~[graylog.jar:?]
at org.joda.time.DateTime.parse(DateTime.java:162) ~[graylog.jar:?]
at org.joda.time.DateTime.parse(DateTime.java:150) ~[graylog.jar:?]
at org.graylog2.syslog4j.server.impl.event.SyslogServerEvent.parse8601Date(SyslogServerEvent.java:156) ~[graylog.jar:?]
at org.graylog2.syslog4j.server.impl.event.SyslogServerEvent.parseDate(SyslogServerEvent.java:125) ~[graylog.jar:?]
at org.graylog2.syslog4j.server.impl.event.structured.StructuredSyslogServerEvent.parseDate(StructuredSyslogServerEvent.java:132) ~[graylog.jar:?]
at org.graylog2.syslog4j.server.impl.event.SyslogServerEvent.parsePriority(SyslogServerEvent.java:178) ~[graylog.jar:?]
at org.graylog2.syslog4j.server.impl.event.SyslogServerEvent.parse(SyslogServerEvent.java:194) ~[graylog.jar:?]
at org.graylog2.syslog4j.server.impl.event.structured.StructuredSyslogServerEvent.<init>(StructuredSyslogServerEvent.java:65) ~[graylog.jar:?]
at org.graylog2.inputs.codecs.SyslogCodec.parse(SyslogCodec.java:136) ~[graylog.jar:?]
at org.graylog2.inputs.codecs.SyslogCodec.decode(SyslogCodec.java:104) ~[graylog.jar:?]
at org.graylog2.shared.buffers.processors.DecodingProcessor.processMessage(DecodingProcessor.java:156) ~[graylog.jar:?]
at org.graylog2.shared.buffers.processors.DecodingProcessor.onEvent(DecodingProcessor.java:94) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:104) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:52) [graylog.jar:?]
at org.graylog2.shared.buffers.PartitioningWorkHandler.onEvent(PartitioningWorkHandler.java:52) [graylog.jar:?]
at com.lmax.disruptor.BatchEventProcessor.processEvents(BatchEventProcessor.java:167) [graylog.jar:?]
at com.lmax.disruptor.BatchEventProcessor.run(BatchEventProcessor.java:122) [graylog.jar:?]
at java.base/java.lang.Thread.run(Unknown Source) [?:?]
A timestamp extractor like described here: Extract timestamp from message
