Meraki Syslog UDP with OVA Graylog v3.0.1+de74b68
Does the new version of Graylog not work with Meraki Syslog UDP? Bit of a noob here so bare with me.
Set up syslog server in my Meraki dashboard (MX64) > using port 10514
In graylog i can see it is receiving logs when i have an Input set to SYSLOG UDP 10514 but i get the following errors in my graylog serverlog:
java.lang.IllegalArgumentException: Invalid format: “1554510730.684963576” is malformed at “0.684963576”
at org.joda.time.format.DateTimeFormatter.parseDateTime(DateTimeFormatter.java:945) ~[graylog.jar:?]
at org.joda.time.DateTime.parse(DateTime.java:160) ~[graylog.jar:?]
at org.joda.time.DateTime.parse(DateTime.java:149) ~[graylog.jar:?]
at org.graylog2.syslog4j.server.impl.event.SyslogServerEvent.parseDate(SyslogServerEvent.java:108) ~[graylog.jar:?]
at org.graylog2.syslog4j.server.impl.event.structured.StructuredSyslogServerEvent.parseDate(StructuredSyslogServerEvent.java:113) ~[graylog.jar:?]
at org.graylog2.syslog4j.server.impl.event.SyslogServerEvent.parsePriority(SyslogServerEvent.java:136) ~[graylog.jar:?]
at org.graylog2.syslog4j.server.impl.event.SyslogServerEvent.parse(SyslogServerEvent.java:152) ~[graylog.jar:?]
at org.graylog2.syslog4j.server.impl.event.structured.StructuredSyslogServerEvent.(StructuredSyslogServerEvent.java:50) ~[graylog.jar:?]
at org.graylog2.inputs.codecs.SyslogCodec.parse(SyslogCodec.java:126) ~[graylog.jar:?]
at org.graylog2.inputs.codecs.SyslogCodec.decode(SyslogCodec.java:96) ~[graylog.jar:?]
at org.graylog2.shared.buffers.processors.DecodingProcessor.processMessage(DecodingProcessor.java:150) ~[graylog.jar:?]
at org.graylog2.shared.buffers.processors.DecodingProcessor.onEvent(DecodingProcessor.java:91) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:74) [graylog.jar:?]
at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:42) [graylog.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_191]
When I use raw UDP for input in graylog it receives logs just fine and can search (although they are a bit messy). I know there is a way to parse them but i am not there yet. Looking for a bit of direction before I waste time.
Thanks,
-Al
Looks like it’s sending a timestamp in Unix Timestamp format, which isn’t entirely kosher from a Syslog format point of view.
