Strange certificate issue (Caused by: java.security.KeyStoreException: Key protection algorithm not found: java.security.KeyStoreException: Certificate chain is not valid)
At one of my customers I have to use a wildcard certificate for Graylog (*.company.hu). When I use this cert/key I’m getting this error
Any idea how to fix this? Similar set-up with explicit certificate works fine
Laszlo
2020-02-18T14:00:57.429+01:00 ERROR [ServerBootstrap] Unable to shutdown properly on time. {STOPPING=[JobSchedulerService [STOPPING]], TERMINATED=[InputSetupService [TERMINATED], MongoDBProcessingStatusRecorderService [TERMINATED], GracefulShutdownService [TERMINATED], UrlWhitelistService [TERMINATED], StreamCacheService [TERMINATED], OutputSetupService [TERMINATED], LookupTableService [TERMINATED], EtagService [TERMINATED], ConfigurationEtagService [TERMINATED], PeriodicalsService [TERMINATED], JournalReader [TERMINATED], BufferSynchronizerService [TERMINATED], KafkaJournal [TERMINATED]], FAILED=[JerseyService [FAILED]]}
2020-02-18T14:00:57.430+01:00 ERROR [ServerBootstrap] Graylog startup failed. Exiting. Exception was:
    at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.checkHealthy(ServiceManager.java:741) ~[graylog.jar:?]
    at com.google.common.util.concurrent.ServiceManager$ServiceManagerState.awaitHealthy(ServiceManager.java:553) ~[graylog.jar:?]
    at com.google.common.util.concurrent.ServiceManager.awaitHealthy(ServiceManager.java:314) ~[graylog.jar:?]
    at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:148) ~[graylog.jar:?]
    at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:210) ~[graylog.jar:?]
    at org.graylog2.bootstrap.Main.main(Main.java:50) ~[graylog.jar:?]
    Suppressed: com.google.common.util.concurrent.ServiceManager$FailedService: JerseyService [FAILED]
            at sun.security.pkcs12.PKCS12KeyStore.setKeyEntry(PKCS12KeyStore.java:704) ~[?:?]
            at sun.security.pkcs12.PKCS12KeyStore.engineSetKeyEntry(PKCS12KeyStore.java:601) ~[?:?]
            at sun.security.util.KeyStoreDelegator.engineSetKeyEntry(KeyStoreDelegator.java:111) ~[?:?]
            at java.security.KeyStore.setKeyEntry(KeyStore.java:1174) ~[?:?]
            at org.graylog2.shared.security.tls.PemKeyStore.buildKeyStore(PemKeyStore.java:125) ~[graylog.jar:?]
            at org.graylog2.shared.initializers.JerseyService.buildSslEngineConfigurator(JerseyService.java:347) ~[graylog.jar:?]
            at org.graylog2.shared.initializers.JerseyService.startUpApi(JerseyService.java:172) ~[graylog.jar:?]
            at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService.java:146) ~[graylog.jar:?]
            at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) ~[graylog.jar:?]
            at com.google.common.util.concurrent.Callables$4.run(Callables.java:119) ~[graylog.jar:?]
            at java.lang.Thread.run(Thread.java:834) ~[?:?]
    Caused by: java.security.KeyStoreException: Certificate chain is not valid
            at sun.security.pkcs12.PKCS12KeyStore.setKeyEntry(PKCS12KeyStore.java:651) ~[?:?]
Check, that your keystore also contains intermediate certificate, because wildcard certificate are usually signed by intermediate certificate, not only root certificate.
So, I’ve imported all the certs one by one
Keystore type: PKCS12
Keystore provider: SUN
Your keystore contains 3 entries
, Feb 19, 2020, trustedCertEntry,
Certificate fingerprint (SHA-256): 9A:7A:3C:A4:76:CE:AA:EB:45:D7:51:EA:66:B4:3D:0C:80:9E:8A:2D:CA:93:FE:B2:D6:CC:DE:A7:7D:82:FF:04
e-szigno-root, Feb 19, 2020, trustedCertEntry,
Certificate fingerprint (SHA-256): 3C:5F:81:FE:A5:FA:B8:2C:64:BF:A2:EA:EC:AF:CD:E8:E0:77:FC:86:20:A7:CA:E5:37:16:3D:F3:6E:DB:F3:78
e-szigno-ssl-ca, Feb 19, 2020, trustedCertEntry,
Certificate fingerprint (SHA-256): EA:C2:41:C0:44:0A:36:83:01:11:38:33:36:BC:20:CA:C7:40:9C:20:F6:E8:8D:4F:84:F4:82:7B:E9:19:E3:38
I also instructed graylog to use this certstore
GRAYLOG_SERVER_JAVA_OPTS=“-Xms2g -Xmx2g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:-OmitStackTraceInFastThrow -Djavax.net.ssl.trustStore=/etc/graylog/server/cacerts.jks -Djavax.net.ssl.trustStorePassword=xxxxxxxxxxx”
But I still have the same error.
Also in my another system I was able to skip this whole step by adding certs to java keystore, but that system based on CentOS7, and this one is Debian10, so maybe this is why.
Laszlo
do you use valid cert from commercial certification authority or your own CA?
If you use wildcard cert from commercial CA, I think, that root cert is already in java truststore. You only need to setup path for certificate and key in graylog server.conf:
https://docs.graylog.org/en/3.2/pages/configuration/https.html
http_enable_tls = true
http_tls_cert_file = /path/to/graylog-certificate.pem
http_tls_key_file = /path/to/graylog-key.pem
If you have intermediate cert, medge it to graylog-certificate.pem with certificate:
cat cert.pem intermediate.pem > graylog-certificate.pem
If you use own CA, you need to insert only root CA to java trustStore:
https://docs.graylog.org/en/3.2/pages/configuration/https.html#adding-a-self-signed-certificate-to-the-jvm-trust-store
After following the official documentation, I was able to start graylog and I was able log-in for a few minutes, but after that I’m getting timeouts while Graylog trying to call /api Any idea how to fix this last piece?
Laszlo
Check your server.conf parameters:
http_publish_uri =
http_external_uri =
It should contain https://
https://docs.graylog.org/en/3.2/pages/configuration/server.conf.html#web-rest-api
Yes, I have these
web_endpoint_uri = https://servername:9000/api/
rest_transport_uri = https://servername:9000/
web_listen_uri = https://servername:9000/
http_publish_uri = https://servername:9000/
http_external_uri = https://servername:9000/
but, I still have
We are experiencing problems connecting to the Graylog server running on https://servername:9000/api/. Please verify that the server is healthy and working correctly
I still may need some last piece of config to make i working… the strange thing is, there are nothing in the logs, the connection simply timeouts
Any idea?
Laszlo
the question @vladx
what Graylog version did you use?
You use settings that are pre and post Graylog 3.0 …
I have the latest version on Debian10. Same version with similar config running seamlessly on CentOS 7 with explicit certificate, so I’m thinking it is maybe related to the certificate or to the OS
Here is my version
graylog-3.2-repository/stable,now 1-1 all [installed]
graylog-integrations-plugins/stable,now 3.2.1-1 all [installed]
graylog-server/stable,now 3.2.1-1 all [installed]
Laszlo
I also noticed a major difference between centos7 and debian 10. On debian I have a much newer openssl version
OpenSSL 1.1.1d 10 Sep 2019
Can it cause issues like this? I’ve created a self signed certificate using the official doc, and I have the same symptoms
Laszlo
So, here is the solution
I’ve tried with both commercial and self signed certificates, but all the same. After a few minutes TLS hung, so I changed Graylog back to default and listening only on localhost/http, installed nginx and configured as reverse proxy with TLS and magically it is working fine. I’m almost sure there is some conflict between latest Graylog TLS implementation and Debain 10 or openssl 1.1
What do you think?
Laszlo
What do you think?
maybe - that is something that could happen. Can you reproduce that in a VM? Can you open a bug report for that over at github with steps how to reproduce this?
thx
Jan
I’ll do my best, but first I have to finish some new implementation :slight_smile: At least it is working
