Graylog blew up after adding SSL Cert
Greetings,
Just added a wildcard certificate to graylog, and am getting a cryptic error when starting…
2017-06-07T10:40:31.293-07:00 ERROR [ServiceManager] Service JerseyService [FAIL ED] has failed in the STARTING state.
java.security.spec.InvalidKeySpecException: Neither RSA, DSA nor EC worked
at org.graylog2.shared.security.tls.PemKeyStore.buildKeyStore(PemKeyStor e.java:110) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.buildSslEngineConfigur ator(JerseyService.java:385) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.startUpWeb(JerseyServi ce.java:149) ~[graylog.jar:?]
at org.graylog2.shared.initializers.JerseyService.startUp(JerseyService. java:141) ~[graylog.jar:?]
at com.google.common.util.concurrent.AbstractIdleService$DelegateService $1.run(AbstractIdleService.java:62) [graylog.jar:?]
at com.google.common.util.concurrent.Callables$4.run(Callables.java:122) [graylog.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
Caused by: java.security.spec.InvalidKeySpecException: java.security.InvalidKeyE xception: IOException : DER input, Integer tag error
at sun.security.ec.ECKeyFactory.engineGeneratePrivate(ECKeyFactory.java: 169) ~[sunec.jar:1.8.0_131]
at java.security.KeyFactory.generatePrivate(KeyFactory.java:372) ~[?:1.8 .0_131]
at org.graylog2.shared.security.tls.PemKeyStore.buildKeyStore(PemKeyStor e.java:108) ~[graylog.jar:?]
… 6 more
Caused by: java.security.InvalidKeyException: IOException : DER input, Integer t ag error
at sun.security.pkcs.PKCS8Key.decode(PKCS8Key.java:351) ~[?:1.8.0_131]
at sun.security.pkcs.PKCS8Key.decode(PKCS8Key.java:356) ~[?:1.8.0_131]
at sun.security.ec.ECPrivateKeyImpl.(ECPrivateKeyImpl.java:73) ~[s unec.jar:1.8.0_131]
at sun.security.ec.ECKeyFactory.implGeneratePrivate(ECKeyFactory.java:23 7) ~[sunec.jar:1.8.0_131]
at sun.security.ec.ECKeyFactory.engineGeneratePrivate(ECKeyFactory.java: 165) ~[sunec.jar:1.8.0_131]
I added the certificate to the java keystore as well… Any suggestions?
Hej @sferguson
the error is produced here in Graylog - did you checked if the Key Format is RSA, DSA or EC?
Please describe what you had done and if you read (what) documentation to solve your issue.
The key appears to be RSA. I followed the documentation to enable SSL for the server
did you check if the Graylog User is able to read the files?
Yes. Graylog user has full RWX access to the folder.
