Note that :// has been {obfuscated} to eliminate detection of extraneous links from config files and cer/key files.
Following the recipe described here: Enable HTTPS using existing certificates bought from GoDaddy - #2 by vneerukonda
We have used openssl to convert our wildcard key and cert and chain files to create a .pfx file, which we then used, following the above recipe, to create dedicated graylog.cer and graylog.key files. We ensured the files are owned by graylog:graylog in a sub-directory of /etc/graylog/ssl also owned by graylog:root
Used the recipe above, created the files, added the new cert to the cacerts.pks, updated the graylog java options file and still are getting the error:
com.github.joschi.jadconfig.ValidationException: Unreadable or missing HTTP X.509 certificate: null
OS Information: Ubuntu 22.04 LTS
Package Version: dpkg --list | grep graylog
ii graylog-5.0-repository 1-2 all Package to install Graylog 5.0 GPG key and repository
ii graylog-server 5.0.5-1 amd64 Graylog server -
Config:
/etc/graylog/server# grep -v ā#ā server.conf | grep -v ^$
is_leader = true
password_secret ={obfuscated}
root_username = admin
root_password_sha2 ={obfuscated}
root_email = āadmin@{obfuscated}.{obfuscated}.orgā
root_timezone = US/Central
http_bind_address = gl5log01.{obfuscated}.com:9000
http_publish_uri = https{obfuscated}gl5log01.{obfuscated}.com:9000/
http_external_uri = https{obfuscated}gl5log01.{obfuscated}.com:9000/
http_enable_cors = true
http_enable_tls = true
http_tls_cert = /etc/graylog/ssl/graylog.cer
http_tls_key_file = /etc/graylog/ssl/graylog.key
elasticsearch_hosts = http{obfuscated}opensearch00:9200,http{obfuscated}opensearch01:9200,http{obfuscated}opensearch02:9200
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_max_size = 6gb
mongodb_uri = mongodb{obfuscated}glogdb01.{obfuscated}.com:27017,glogdb02.{obfuscated}.com:27017/graylog?replicaSet=MongoCluster
mongodb_version_probe_attempts = 5
transport_email_hostname = smtp01.{obfuscated}.com
transport_email_port = 25
transport_email_from_email = noreply@{obfuscated}.com
enabled_tls_protocols = TLSv1.2,TLSv1.3
skip_preflight_checks = false
Folder where cer and key reside:
/etc/graylog/ssl# ll
total 28
drwxr-xr-x 3 graylog root 4096 Mar 31 13:09 ./
drwxr-xr-x 4 root root 4096 Mar 30 10:46 ā¦/
lrwxrwxrwx 1 root root 27 Jan 24 13:02 cacerts.jks ā /etc/ssl/certs/java/cacerts
-rw------- 1 graylog graylog 2594 Mar 31 12:22 graylog.cer
-rw------- 1 graylog graylog 1832 Mar 31 12:23 graylog.key
drwxr-xr-x 4 root root 4096 Mar 31 13:09 old/
-rw------- 1 root root 6963 Mar 31 12:21 wildcard.{obfuscated}.com.pfx
Beginning of graylog.cer file:
:/etc/graylog/ssl# cat graylog.cer
Bag Attributes
localKeyID: AB FB 93 FD 5E 91 53 B3 78 06 37 F1 7A 0B 12 96 C8 CC 3A 08
subject=CN = *.gvtc.com
issuer=C = US, ST = Arizona, L = Scottsdale, O = āGoDaddy {dot}com, Inc.ā, OU = http{obfuscated}certs.godaddy {dot} com/repository/, CN = Go Daddy Secure Certificate Authority - G2
-----BEGIN CERTIFICATE-----
MIIGgTCCBWmgAwIBAgIITRwrDwj+cqcwDQYJKoZIhvcNAQELBQAwgbQxCzAJBgNV
BAYTAlVTMRAwDgYDVQQIEwdBcml6b25hMRMwEQYDVQQHEwpTY290dHNkYWxlMRow
{remainder deleted}
Contents of graylog.key file:
/etc/graylog/ssl# cat graylog.key
Bag Attributes
Key Attributes:
-----BEGIN PRIVATE KEY-----
MIIEvwIBADANBgkqhkiG9w0BAQEFAASCBKkwggSlAgEAAoIBAQDd3mliS0Vs+Pv0
4ZT38WUYcGdM8p7HymuN3xkTCXr2fQcZUzggFA5bm4xsucqWUCZK28qRo0qaqiEw
{remainder deleted}
Multiple paths and methods of converting apache, tomcat, iis versions of GoDaddy certificate files to formats that would be acceptable to Graylog.
Really not sure why the standard Tomcat version wonāt simply work without conversions, but no method of converting using openssl has worked for us so far.
Weāve found many places where folks are using self signed certs, but only a couple references to using a wildcard public signed cert from a recognized CA authority and only the .pfx version, which my provider, GoDaddy doesnāt provide, is even mentioned for an effective recipe for conversion.
Identify a pathway to take a standard certificate/key file from a national provider and make it work.
It would also be nice if the documentation links from inside Graylog would work for older versions instead of all generating a 404 error, but thatās a different issueā¦
We have an existing graylog4 deployment and are trying to build a new graylog5 with new backend storage using latest OSes and packages, this time enabling security as it is intended to be used by external departments and are finding it exceedingly difficult to get this working. Itās extremely frustrating to be trying seemingly random openssl conversion routines when documentation could share a recipe for use of one of the standard 3 formats of fully signed public certificates (apache, tomcat or even, iis).
