SSO works without trusted_proxies
Im trying to setup SSO on my graylog servers. I built a vanilla graylog lab for testing. I also have ldap enabled which i can log with.
Yes i have read the docs but no go :frowning: http://docs.graylog.org/en/2.4/pages/users_and_roles/external_auth.html?highlight=sso#single-sign-on
Enviroment:
graylog-2.4-repository-1-5.noarch
graylog-plugin-auth-sso-2.4.2-1.noarch
graylog-server-2.4.3-1.noarch
Single Sign-On Configuration
Username Header 'X-Forwarded-User'
[] - Request must come from a trusted proxy (this is unchecked)
[x] - Automatically create users (this is checked)
(all other fields are blank or "Reader")
grep proxies /etc/graylog/server/server.conf
trusted_proxies = 10.xxx.xx.210/32, xxx:xxx:xx:xx::210/128
Graylog is behind nginx proxy /etc/nginx/nginx.conf:
	resolver 127.0.0.1;
	location /auth_verify {
		internal;
		proxy_pass_request_body off;
		proxy_set_header  X-Original-URI $request_uri;
		proxy_set_header  X-Real-IP $remote_addr;
		proxy_set_header  Host $http_host;
		proxy_set_header  Content-Length "";
		proxy_pass  https://login.nwk.jwm2.net/api/verify;
location /graylog {
	include test_authelia_params;
	access_log /var/log/nginx/back.log addHeaderlog ;
	proxy_set_header X-Graylog-Server-URL https://$server_name/graylog/api;
	proxy_pass       http://127.0.0.1:9000/graylog;
/etc/nginx/test_authelia_params
auth_request /auth_verify;
auth_request_set $redirect $upstream_http_redirect;
proxy_set_header Redirect $redirect;
auth_request_set $user $upstream_http_remote_user;
proxy_set_header X-Forwarded-User $user;
auth_request_set $groups $upstream_http_remote_groups;
proxy_set_header Remote-Groups $groups;
error_page 401 =302 https://login.nwk.jwm2.net?redirect=$redirect;
The login.nwk.jwm2.net is the authority server which also has 2FA. Which is configured in trusted_proxies
The issue is that when i uncheck the request must come from a trusted proxy i can get it using the X-Forwarded-User header which my login server sets ( i can see it in the logs). When i check it i can never get in even if the X-Forwarded-User is set :frowning:
Any input is appreciated
BTW im using authelia as the auth server
thank you,
dave
The trusted proxy in this case is the nginx proxy, which provides the HTTP headers to Graylog.
Ohhh :open_mouth:
ok ok let me try!
thank you @jochen
That was it!!
trusted_proxies = 127.0.0.1/32, ::1/128
thanks again @jochen
