Hi everybody,
does anybody here have simple, working sso config for apache here?
I’m stuck.
I am able to pass the Apache Auth. I see Remote-User Header, but then i see only the standard Graylog Login page.
I appreciate any help!
Hi everybody,
I’m stuck.
A typical mistake is that the IP address of the proxy server (Apache httpd in your case) is missing in the trusted_proxies setting in Graylog.
Thank you for your help already.
I made this setting, but it’s not working either.
Here is the main snip of the apache config file
<Proxy *> Order deny,allow Allow from all </Proxy> <Location /> AuthType Kerberos AuthName "DOMAIN LOGIN (HTTPS)" KrbMethodNegotiate off KrbAuthoritative on KrbVerifyKDC off KrbAuthRealms DOMAINNAME require valid-user RequestHeader set X-Graylog-Server-URL "https://192.168.1.1:10443/api/" Header set X-Forwarded-User %{REMOTE_USER}s ProxyPass http://127.0.0.1:9000/ ProxyPassReverse http://127.0.0.1:9000/ </Location>
