I am trying to set up Single Sign-On with an apache reverse proxy. The proxy sets REMOTE_USER header and I enabled Trusted Header Authentication in the Graylog Webinterface in the System Authentication settings. Unfortunately it doesn’t work. the first call to /graylog/api/ will be rejected by my apache with a 401. And I get stuck on the login screen saying “Loading, please wait…”
Apache access.log:
xxx.xxx.xxx.xxx - my_user [08/Nov/2022:17:38:33 +0000] "GET /graylog HTTP/1.1" 200 440
xxx.xxx.xxx.xxx - my_user [08/Nov/2022:17:38:33 +0000] "GET /graylog/config.js HTTP/1.1" 200 177
xxx.xxx.xxx.xxx - my_user [08/Nov/2022:17:38:33 +0000] "GET /graylog/assets/polyfill.472622149827c1587209.js HTTP/1.1" 200 72152
xxx.xxx.xxx.xxx - my_user [08/Nov/2022:17:38:33 +0000] "GET /graylog/assets/vendor.7b2e72342f604d7babb9.js HTTP/1.1" 200 356045
xxx.xxx.xxx.xxx - my_user [08/Nov/2022:17:38:33 +0000] "GET /graylog/assets/builtins.472622149827c1587209.js HTTP/1.1" 200 280639
xxx.xxx.xxx.xxx - my_user [08/Nov/2022:17:38:33 +0000] "GET /graylog/assets/app.472622149827c1587209.js HTTP/1.1" 200 1371253
xxx.xxx.xxx.xxx - my_user [08/Nov/2022:17:38:33 +0000] "GET /graylog/assets/plugin/org.graylog.plugins.threatintel.ThreatIntelPlugin/plugin.org.graylog.plugins.threatintel.ThreatIntelPlugin.4d62b9d2b0bdce76aa29.js HTTP/1.1" 200 916732
xxx.xxx.xxx.xxx - my_user [08/Nov/2022:17:38:33 +0000] "GET /graylog/assets/plugin/org.graylog.aws.AWSPlugin/plugin.org.graylog.aws.AWSPlugin.47c1f4ee3665343bbc9f.js HTTP/1.1" 200 889513
xxx.xxx.xxx.xxx - my_user [08/Nov/2022:17:38:33 +0000] "GET /graylog/assets/plugin/org.graylog.plugins.collector.CollectorPlugin/plugin.org.graylog.plugins.collector.CollectorPlugin.2c202c07057af33e6166.js HTTP/1.1" 200 932169
xxx.xxx.xxx.xxx - undefined [08/Nov/2022:17:38:34 +0000] "GET /graylog/api/system/sessions HTTP/1.1" 401 381
xxx.xxx.xxx.xxx - my_user [08/Nov/2022:17:38:35 +0000] "GET /graylog/api/ HTTP/1.1" 200 233
My apache config:
<Location /graylog>
ProxyPass "https://some_other_machine/graylog/"
ProxyPassReverse "https://some_other_machine/graylog/"
# my auth stuff
<RequireAll>
Require valid-user
</RequireAll>
RewriteEngine On
RewriteCond %{REMOTE_USER} (.*)
RewriteRule .* - [E=X_REMOTE_USER:%1]
RequestHeader set REMOTE_USER %{X_REMOTE_USER}e
RequestHeader unset Authorization
</Location>
I got trusted_proxy set
The user my_user exists and has { “external_user”: false } set
If I do: RequestHeader set REMOTE_USER my_user the user is logged in
I read this:
opened 05:35AM - 20 Nov 19 UTC
feature
## Expected Behavior
It should be possible to use graylog behind a reverse prox… y that requires HTTP authentication.
## Current Behavior
Behind a reverse proxy that requires HTTP authentication, a user cannot get past graylog's login screen.
Refresher: HTTP authentication works by sending a `Authorization` header containing a base64-encoded string containing `user:password`; for instance, HTTP authentication for user `foo` and password `bar` means the browser sends `Authorization: basic Zm9vOmJhcg==` on _each_ request to graylog, not only on the login page.
graylog unfortunately uses the same header name for session management; `XmlHttpRequests` are sent to the API using a customized `Authorization` string, containing a session UUID; for instance, a javascript call could include a `Authorization: basic YmRlMzE2ZDMtNDJhYi00OGU3LWFkNTEtMzc2Y2RjMzEyMDFjOnNlc3Npb24=`.
So either the reverse proxy refuses the authentication because it was clobbered by graylog and does not match any user anymore, or graylog API denies access because it expects a session management UUID, not a `user:password` combo. In any case, the user cannot go past the login page.
## Possible Solutions
Each of those would work for me AFAICT:
* Graylog could use another header name (such as `X-Graylog-Authorization` instead of `Authorization`) for its session management. To allow backwards compatibility, the HTTP header name could be set via a configuration variable with its default set as `Authorization`.
* Graylog could drop usage of HTTP headers for session management and move that session token to a cookie.
* Graylog could manually pass session UUID as a GET/POST parameter on API requests.
* Assuming a single username cannot have more than one session, graylog could accept a `username:password` `Authorization` as a unique session identifier instead of enforcing a `UUID:session` string.
## Context
Because it is company policy (for security, auditing and other purposes) to enforce HTTP auth for internal services, I cannot currently deploy graylog for said company.
## Your Environment
Running the `graylog-3.1.3-1.ova` appliance.
opened 10:24PM - 19 Jan 21 UTC
documentation
triaged
Upgrading our Graylog server from 3.3.9 to 4.0.1 (and removing the old SSO plugi… n) caused SSO to stop working for existing users.
SSO works using the trusted HTTP header authentication feature that is now built-in.
## Current Behavior
Users authenticated with our external auth provider are not authenticated in Graylog, and are unable to login.
Logs:
2021-01-19 21:10:27,911 TRACE: org.apache.shiro.mgt.DefaultSecurityManager - Context already contains a SecurityManager instance. Returning.
2021-01-19 21:10:27,911 TRACE: org.apache.shiro.mgt.DefaultSecurityManager - No identity (PrincipalCollection) found in the context. Looking for a remembered identity.
2021-01-19 21:10:27,911 TRACE: org.apache.shiro.mgt.DefaultSecurityManager - No remembered identity found. Returning original context.
2021-01-19 21:10:27,911 TRACE: org.apache.shiro.subject.support.DelegatingSubject - attempting to get session; create = false; session is null = true; session has id = false
2021-01-19 21:10:27,911 TRACE: org.apache.shiro.mgt.DefaultSubjectDAO - Session storage of subject state for Subject [org.apache.shiro.subject.support.DelegatingSubject@1ac7cf73] has been disabled: identity and authentication state are expected to be initialized on every request or invocation.
2021-01-19 21:10:27,911 TRACE: org.apache.shiro.authc.AbstractAuthenticator - Authentication attempt received for token [org.graylog2.shared.security.HttpHeadersToken@7650930f]
2021-01-19 21:10:27,911 TRACE: org.apache.shiro.authc.pam.ModularRealmAuthenticator - Iterating through 5 realms for PAM authentication
2021-01-19 21:10:27,911 DEBUG: org.apache.shiro.authc.pam.ModularRealmAuthenticator - Realm [org.graylog2.security.realm.SessionAuthenticator@42f1785d] does not support token org.graylog2.shared.security.HttpHeadersToken@7650930f. Skipping realm.
2021-01-19 21:10:27,911 DEBUG: org.apache.shiro.authc.pam.ModularRealmAuthenticator - Realm [org.graylog2.security.realm.AccessTokenAuthenticator@16c97452] does not support token org.graylog2.shared.security.HttpHeadersToken@7650930f. Skipping realm.
2021-01-19 21:10:27,911 TRACE: org.apache.shiro.authc.pam.ModularRealmAuthenticator - Attempting to authenticate token [org.graylog2.shared.security.HttpHeadersToken@7650930f] using realm [org.graylog2.security.realm.HTTPHeaderAuthenticationRealm@74c53f7e]
2021-01-19 21:10:27,913 DEBUG: org.graylog2.security.realm.HTTPHeaderAuthenticationRealm - Attempting authentication for username <xyz@abc.com>
2021-01-19 21:10:27,914 DEBUG: org.graylog2.cluster.ClusterConfigServiceImpl - Couldn't find cluster config of type org.graylog.security.authservice.GlobalAuthServiceConfig.Data
2021-01-19 21:10:27,914 DEBUG: org.graylog.security.authservice.backend.MongoDBAuthServiceBackend - Trying to load user <xyz@abc.com> from database
2021-01-19 21:10:27,914 DEBUG: org.graylog2.users.UserServiceImpl - Loading user xyz@abc.com
2021-01-19 21:10:27,915 DEBUG: org.graylog2.users.UserServiceImpl - Loaded user xyz@abc.com/5e441ca046e2bc0001e6c459 from MongoDB
2021-01-19 21:10:27,915 TRACE: org.graylog.security.authservice.backend.MongoDBAuthServiceBackend - Skipping mongodb-based password check for external user xyz@abc.com
2021-01-19 21:10:27,915 WARN : org.graylog2.security.realm.HTTPHeaderAuthenticationRealm - Failed to authenticate username <xyz@abc.com> from trusted HTTP header <X-Auth-Request-Email> via proxy <10.43.70.102>
2021-01-19 21:10:27,915 DEBUG: org.apache.shiro.realm.AuthenticatingRealm - Looked up AuthenticationInfo [null] from doGetAuthenticationInfo
2021-01-19 21:10:27,915 DEBUG: org.apache.shiro.realm.AuthenticatingRealm - No AuthenticationInfo found for submitted AuthenticationToken [org.graylog2.shared.security.HttpHeadersToken@7650930f]. Returning null.
2021-01-19 21:10:27,916 DEBUG: org.apache.shiro.authc.pam.ModularRealmAuthenticator - Realm [org.graylog2.security.realm.AuthServiceRealm@77fb684c] does not support token org.graylog2.shared.security.HttpHeadersToken@7650930f. Skipping realm.
2021-01-19 21:10:27,916 DEBUG: org.apache.shiro.authc.pam.ModularRealmAuthenticator - Realm [org.graylog2.security.realm.RootAccountRealm@3e81d57e] does not support token org.graylog2.shared.security.HttpHeadersToken@7650930f. Skipping realm.
2021-01-19 21:10:27,916 DEBUG: org.graylog2.shared.security.ShiroAuthenticationFilter - Unable to authenticate user.
The credentials passed to `authenticateAndProvision` are [already authenticated when they're created](https://github.com/Graylog2/graylog2-server/blob/4.0.1/graylog2-server/src/main/java/org/graylog2/security/realm/HTTPHeaderAuthenticationRealm.java#L115), so if the `user.isExternalUser()` check that is causing these problems were removed [the password check would still be skipped](https://github.com/Graylog2/graylog2-server/blob/4.0.1/graylog2-server/src/main/java/org/graylog/security/authservice/backend/MongoDBAuthServiceBackend.java#L81-L86) and users would be successfully authenticated.
Does it make sense to just remove that `user.isExternalUser()` check to get SSO working for these users again? Or is that required for some other use-case?
## Steps to Reproduce (for bugs)
1) Migrate from 3.3.x to 4.0.x with users that were [created automatically by the legacy SSO plugin](https://github.com/Graylog2/graylog-plugin-auth-sso/blob/3.3.0/src/main/java/org/graylog/plugins/auth/sso/SsoAuthRealm.java#L115-L121).
2) The `HTTPHeaderAuthenticationRealm` [creates an authenticated user object from the request data and calls `authenticate`](https://github.com/Graylog2/graylog2-server/blob/4.0.1/graylog2-server/src/main/java/org/graylog2/security/realm/HTTPHeaderAuthenticationRealm.java#L115-L116).
3) The `AuthServiceAuthenticator` [triggers a call to `authenticateAndProvision` for the configured backend](https://github.com/Graylog2/graylog2-server/blob/368c68e4a3810f34a0983be5cd68a40d1e444d54/graylog2-server/src/main/java/org/graylog/security/authservice/AuthServiceAuthenticator.java#L94).
4) The user is marked as `external`, so [an `Optional.empty` is returned instead of an authenticated user](https://github.com/Graylog2/graylog2-server/blob/368c68e4a3810f34a0983be5cd68a40d1e444d54/graylog2-server/src/main/java/org/graylog/security/authservice/backend/MongoDBAuthServiceBackend.java#L76-L80).
5) The `Optional.empty` response [causes the `authenticate` call to fail](https://github.com/Graylog2/graylog2-server/blob/368c68e4a3810f34a0983be5cd68a40d1e444d54/graylog2-server/src/main/java/org/graylog/security/authservice/AuthServiceAuthenticator.java#L97).
## Context
Existing SSO users can't login.
## Your Environment
* Graylog Version: 4.0.1-1 (Docker)
* Java Version: 1.8.0_275
* Elasticsearch Version: 6.8.9
* MongoDB Version: 4.2
* Operating System: Flatcar Container Linux by Kinvolk 2605.6.0 (Oklo)
* Browser version: Chrome 87.0.4280.141
Running on Kubernetes, SSO provided by oauth2-proxy/nginx-ingress-controller
and it seems to me that SSO should be possible by setting the REMOTE_USER header. I will need to create the users manually and I am ok with that.
OS Information: Centos 8
Package Version: Graylog 4.2.13
Is this approch viable at all?
Why is the request to graylog/api not authenticated?
How can I debug this?
Any Ideas are welcome, thanks!
gsmith
(GSmith)
November 9, 2022, 4:31am
2
Hello @Robert1
To be honest, I could not get it to work either. Only way I was able to get SSO to work was install the Enterprise/Operation version for testing. Maybe some one else here was able to achieve this.
Hello @gsmith ,
thanks for the reply.
It seems @marif made it work as stated here:
Yes this is true, for better clarity look here
EDIT:
Only the Trusted Header will work for Open source, but if you keep under 2Gb a day the Enterprise license is free.
It would be great if he could help.
