Hi there.
Could somebody explain how does " Trusted Header Authentication" should be configured to works properly?
I want to be able to auth into Graylog with my google account.
For now, I use GitHub - bitly/oauth2_proxy: A reverse proxy that provides authentication with Google, Github or other provider for authentication into my ELK and it works pretty well.
Does nobody use oauth for Graylog?
For somebody who will face with the same question.
A simple example - add into the nginx vhost config
proxy_set_header Graylog-User testuser;
where:
- Graylog-User - a header that I set up in the Trusted Header Authentication menu.
- testuser - Graylog user which will be authenticated in the web interface. It can’t be local admin user!
My full nginx config:
server {
listen 443 ssl;
server_name graylog.domain.net;
ssl_certificate /etc/nginx/ssl/domain.net.pem;
ssl_certificate_key /etc/nginx/ssl/domain.net.key;
location / {
proxy_pass http://127.0.0.1:4180;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Scheme $scheme;
proxy_connect_timeout 15;
proxy_send_timeout 30;
proxy_read_timeout 30;
# Authorized proxy for Graylog
server {
listen 8080;
server_name 127.0.0.1;
location / {
proxy_set_header X-Graylog-Server-URL https://$server_name/;
proxy_pass http://127.0.0.1:9000;
proxy_connect_timeout 60;
proxy_send_timeout 60;
proxy_read_timeout 60;
send_timeout 60;
/etc/oauth2_proxy.cfg :
# based on https://github.com/bitly/oauth2_proxy/blob/master/contrib/oauth2_proxy.cfg.example
email_domains = [
"domain.corp",
"domain2.corp"
upstreams = [
"http://127.0.0.1:8080/"
pass_basic_auth = false
redirect_url = "https://graylog.domain.net/oauth2/callback"
cookie_name = "_oauth2_proxy"
cookie_secret = "secret_key"
cookie_secure = true
client_id = "id.apps.googleusercontent.com"
client_secret = "secret_key"
