blason
(Blason)
September 28, 2020, 2:54am
1
Hi Team,
I need a help with graylog-sso plugin configuration with nginx reverse proxy basic-auth. Has anyone achieved that?
Here is my nginx config
listen 80 ;
server_name portal.graylog.test;
# return 301 https://$server_name$request_uri;
add_header X-Frame-Options "SAMEORIGIN";
access_log /var/log/nginx/graylog/access.log;
error_log /var/log/nginx/graylog/error.log;
location / {
auth_basic "Login";
auth_basic_user_file "/etc/nginx/.htpasswd";
client_max_body_size 10m;
client_body_buffer_size 128k;
proxy_send_timeout 90;
proxy_http_version 1.1;
proxy_read_timeout 90;
proxy_buffer_size 128k;
proxy_buffers 4 256k;
proxy_busy_buffers_size 256k;
proxy_temp_file_write_size 256k;
proxy_connect_timeout 30s;
proxy_pass http://192.168.5.111:9000;
proxy_set_header X-Graylog-Server-URL http://$server_name/;
proxy_set_header Host $host;
proxy_set_header Remote-User $remote_user;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Requested-By $remote_addr;
location /api/ {
proxy_pass http://portal.graylog.test:9000/api/;
And my Graylog config
Have downloaded SSO plugin
Installed in plugin directory
Single Sign on at first place
Username Header Remote-User
Trusted proxies defined 192.168.5.0/24
Am I missing anything?
blason
(Blason)
September 28, 2020, 3:39am
2
Ok - I made some progress but still not able to use SSO
server {
listen 80 ;
auth_basic "Login";
location / {
location /api/ {
proxy_pass http://192.168.5.111/api/;
proxy_set_header X-Graylog-Server-URL http://$server_name/api/;
Now getting this error
Error message
cannot GET http://portal.graylog.test/api/ (502)
emerchalegre
(Emerson Chalegre)
September 29, 2020, 8:23pm
3
Hi.
Were you able to use the plugin?
Can you help me?
blason
(Blason)
October 1, 2020, 4:14am
4
Nah - I am still stuck.
Looking for assistance from community.
There is a comment from the dev on GitHub, that the plugin/Auth process in Graylog needs to be rewritten…
I switched to basic Ldaps via AD…
oscarlo
(oscar.lofwenhamn)
October 14, 2020, 8:12am
7
I’m working on something similar, and was able to get a workaround by whitelisting the /api path in the auth proxy. I believe it is required since Graylog does its own calls to the API, which don’t have auth that satisfy the demands from Nginx.
